Which bullet?
Old Sep 26, 2007 | 08:49 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Which bullet?
I'm gonna be running shorty headers into a 3" exhaust with a dynomax bullet muffler. I have no idea what size to use. Any suggestions?
Old Sep 26, 2007 | 12:37 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Which bullet?
You didn't supply much info, it depends on your combo and what kind of noise level you like. Big inches rad motor, run a 3.5", 305 with stock heads/cam/intake, run the 3". Obviously the 3.5 will be louder, especially when the RPMs go up.
Good luck
TA
Old Sep 26, 2007 | 02:00 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Which bullet?
3inch on 305 is a joke unless your talking about y pipe to a single exhaust.
Old Sep 26, 2007 | 02:46 PM
Demon355's Avatar
Re: Which bullet?
I'm running Hooker shorties, Custom Y-pipe w/3" collector, 3" piping into Dynatek cat, 3" piping into Bullet muffler (in the I-pipe), 3" over axle and dumps for now. Eventually it will get 4thgen tips. My bullet is the longer version and 3". Sounds mean as hell.
Old Sep 27, 2007 | 07:41 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: Which bullet?
yeah I knew I shoulda put more info...its a carbed 355 with aftermarket heads and cam..and yeah I want it pretty loud but most imprantly I want it to sound mean.
Old Sep 27, 2007 | 08:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Which bullet?
But do you want a single or true dual setup is the real question. I have an 84 Z28 with a 355 pushing 400hp. I have long tube headers and moroso spiral mufflers and all this is true dual exhaust and 2.5 inch pipe.. The moroso spirals are very similar to the bullets but from what I hear there a little louder. My car does sound very loud and very mean but I have to pretty much idle by cops because its so loud. And if I mash the gas you can here me from 2miles away. You dont want to go more than 2.5 in with a true dual setup on your 355 unless your pushin out some mega hp.
Old Sep 27, 2007 | 09:15 AM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: Which bullet?
I wanna go with a single, ground clearence is an issue. Can I get dual tips out of a single bullet set up?
Old Sep 27, 2007 | 09:47 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Which bullet?
I dont know much about how much a single exhuast can handle hp wise vs dia. You might want to do a search and see what other people have done in the past. And for dual tips you could get them anywhere and have a muffler shop just weld the tip onto the exhaust pipe.
Old Sep 27, 2007 | 12:30 PM
Stephen's Avatar
Car: 87 GTA
Re: Which bullet?
Here's my single Magnaflow bullet cat-back, with dual tips...
Texas Speed & Performance LS1 Rumbler cat back.
GTAman
Jul 3, 2024 07:29 PM
Fronzizzle
Feb 9, 2017 09:31 AM
billybob6110
Sep 24, 2016 09:50 AM
Logan Bryant
Sep 18, 2016 09:27 AM
GTAman
Aug 27, 2015 10:29 PM
