SIDEPIPES
Old Jan 4, 2008 | 08:12 AM
  #51
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: SIDEPIPES
Your car is your car...Ill never say something looks stupid. I might think it, but like I said. Its yours...
However here is my opinion on sidepipes. I think they only look good tucked, and moulded into the car. Unless you are driving a cobra or old vette...
Here is a 4th gen bird that someone did recently. It took extra work, yes. But looks phenominal IMO. I believe those are Porsche 996 Turbo tips. I also think it might be easier on our thirdgens with GFX... there seems to be more there on a thirdgen. So making that cut out would probably be easier, and less mods to the chassis may be possible.
Sometimes you gotta just step it up and take that extra little bit and it will pay off.
But if the pipes hanging along the side is your thing...go for it.
J.
Old Jan 4, 2008 | 09:27 AM
  #52
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: SIDEPIPES
That 4th gen does look good, EXCEPT that the whole rear bumper on those cars are molded around the exhaust tips which are not there. However, that is more of a reason to try it on a 3rd gen!
Old Jan 4, 2008 | 10:13 AM
  #53
AC's Avatar
AC
Car: Used to drive a camaro
Re: SIDEPIPES
Looks really good IMO also but that'd never work with my SFC's....
Old Jan 4, 2008 | 11:02 AM
  #54
92rs25thproject's Avatar
Car: 92 rs 25th anniversay edition
Axle/Gears: 3:49 stock
Re: SIDEPIPES
I wanted that kind of look so I took the way cheaper route by taking the stock exhaust that was already hacked off at the rear axle, cut the pipe where it transitions 45 degrees heading towards the driveshaft, welded in a thrush magnum glasspack, reused the stock 45 degree bend, ran about 6" of straight pipe then used another 45 degree bend from advance, and had enough straight tubing leftover to run it to the rear, until I got bigger tires for the rear, and had to notch the pipe with an angle grinder, hammer it straight, weld it back together but it dumps out in front of the passenger rear tire and sounds mean as ****, not to mention it blows the smoke out when I roast the tire ( yes one wheel wonder but not for long )
Old Jan 4, 2008 | 11:40 AM
  #55
Car: 86 Trans AM
Re: SIDEPIPES
Yeah. I think the owner of that particular car is going to add pieces to that to give a road car look. LIke the back of some ferraris and road racers. With the air diverters... Know what i mean?
Either way, Im willing to bet you could fill that area, or modify it to look better. make a false panel or fiberglass it or something.
SFCs might be an issue, but anythings possible. It would make it more difficult. There are some talented peopel out there, Im sure someone could pull it off.
J.
Old Jan 4, 2008 | 04:03 PM
  #56
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Re: SIDEPIPES
my exhuast hits almost every speed bump i go over and all you can see under my car from the side is big rusty pipes. that 4th gen looks sweet
Old Jan 5, 2008 | 11:11 AM
  #57
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Re: SIDEPIPES
rat rods, street rods, 427 cobra's and classic vettes with side pipes = cool.
Camaro/firebirds with side pipes = not cool
I do agree done properly like the 4th above can be cool.
Old Jan 5, 2008 | 04:50 PM
  #58
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: SIDEPIPES
Hey if you need to be noticed that bad why not just run stacks out the hood!
Old Jan 6, 2008 | 02:17 PM
  #59
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
Re: SIDEPIPES
i dont liek side pipes, however it is cool to dump the exhaust right in front of the rear tire on a side exit, thats how i had my old one set up, till my buddy decided to drive over a speed bump and destroy it, so i just put a whole magnaflow catback on
i wish i had a good clip of my car with that set up, i cut the cat, stuck on straight pipe, put a force pro series muffler that i got for $30 from summit on (flow 40 knock-off) and put it right out the side, sounded awesome, everyone but my neighbors loved it, and it set off car alarms
best clip i got
http://vids.myspace.com/index.cfm?fu...ideoID=6637783
Old Jan 7, 2008 | 10:31 AM
  #60
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Re: SIDEPIPES
CHECK THESE SIDEPIPES OUT!!! CUSTOM 4" STAINLESS PIPES COME OFF MODIFIED HOOKER LONG TUBES. REBUILT GROUND EFFECTS FROM STEEL. 13 PCS OF SHEET METAL TO MAKE EACH, TIG WELDED W/SILICONE BRONZE ROD & PAINTED TO MATCH. NOT A JOB FOR THE FAINT OF HEART!!!! MUST USE SOLID FRONT MOTOR MOUNTS OR YOUR CAR WILL DESTROY YOUR HEADERS AND /OR PIPES!! PURCHASED BENDS FROM BURNS STAINLESS. MADE THEM A 4 INTO ONE FOR LOOKS BUT ALL PIPES ARE FUNCTIONAL. FASTENED PIPES TO CUSTOM WELD IN SUB FRAME CONNECTORS I BUILT. ANY ONE WHO SAYS SIDE PIPES CAN'T LOOK GOOD ON 3 GENS NEVER SAW MINE. I HAVE NEVER HAD ANYTHING BUT MAJOR COMPLIMENTS!!!
Old Jan 7, 2008 | 10:46 AM
  #61
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: SIDEPIPES
Let the motor do the talking for you. Avoid being flashy.
Old Jan 7, 2008 | 11:26 AM
  #62
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Re: SIDEPIPES
Nice. I like those.
So, the GFX are steel?
I'd expect fiberglas to melt . . .
Any sound clips of the car?
Old Jan 7, 2008 | 11:56 AM
  #63
topradman's Avatar
Car: 91 Z28
Re: SIDEPIPES
YEA, THE EFFECTS ARE STEEL. I CUT UP NONBLUED SHEET METAL AND TIG WELDED ALL THE PIECES TOGETHER, PREPED AND PAINTED TO MATCH. SORRY, NO SOUND CLIPS BUT VERY LOUD. MADE INSERTS FOR THEM AND PACKED WITH STAINLESS STEEL WOOL. MADE INSERTS FROM BURNS STAINLESS CONNICAL PIECES TO FORM A LONG HOUR GLASS INSERT, PERFORATED WITH A PLASMA ARC, PACKED WITH THE WOOL AND FORCED THEM INSIDE. CAR IS PRETTY LOUD BUT SOUND IS DIRECTED AWAY FROM CAR SO NOT BAD INSIDE. WORST PART IS SOLID MOTOR MOUNTS SO YOU FEEL EVERY BIT OF THE MOTOR EVEN THOUGH IT'S BALANCED. DEFINITELY NOT STREET LEGAL WHEN THE NEW EMISSION INSPECTION LAWS GO TO 50 STATES AS SOON AS THIS YEAR, HOWEVER IF YOUR IN THE CAR BUSINESS THERE WILL BE A WAY AROUND IT. MOST CARS WILL HAVE TO BE CHANGED BACK TO MEET EMISSIONS THOUGH AND THIS IS A VERY PRICEY MODIFICATION EVEN THOUGH I DID ALL BUT THE PAINT JOB MYSELF. THANKS FOR THE COMPLIMENT.....TOPRADMAN dba.,BEST RADIATOR REPAIR, WAREHOUSE & CUSTOM MUFFLER CENTER, HOME OF THE "BADASS" SERIES CUSTOM ALUMINUM RADIATOR.
Old Jan 7, 2008 | 12:12 PM
  #64
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: SIDEPIPES
yeah those sidepipes are done really well, looks good, shame its got that fugly hood though..
Old Jan 7, 2008 | 01:49 PM
  #65
topradman's Avatar
Car: 91 Z28
Re: SIDEPIPES
FUGLY HOOD HUH? MIGHT BE THE ANGLE OF THE PICS. HAVE HAD GOOD COMMENTS ON HOOD TOO. EVERYBODY PUTS ON THOSE COWL HOODS, NOW THAT'S ORDINARY AND FUGLY!!!! MINE'S FUNCTIONAL AND CRAMS AIR INTO BLOWER INTAKE FOR ATI. WANT TO SEE SOMETHING ELSE THAT'S FUGLY BUT KICKS *** OVER "ORDINARY"?!!!!
Old Jan 7, 2008 | 01:50 PM
  #66
topradman's Avatar
Car: 91 Z28
Re: SIDEPIPES
HERE'S ANOTHER ONE OF MY FUGLY MOTOR TOO.
Old Jan 7, 2008 | 04:55 PM
  #67
topradman's Avatar
Car: 91 Z28
Re: SIDEPIPES
Old Jan 7, 2008 | 06:50 PM
  #68
Car: 84 Z28
Engine: carb 305
Re: SIDEPIPES
Your car is really nice i just dont like the sidepipes or hood bonnet. Nice work on the engine too
Old Jan 7, 2008 | 07:35 PM
  #69
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: SIDEPIPES
here is a 2nd gen camaro with side pipes.
http://youtube.com/watch?v=clinIyUHCV0&feature=related
but i think for a 3rd gen car you gotta have your car look like it should have side pipes.
good rims, paint, stylsh hood. or have a blower sticking out of it.
and a supier strong engine and good exhaust sound and everything then maybe sidepipes.
i was thinking of putting m on my car. but i wouldnt be able to get off my driveway because i got a dip at the end and it would just scape the bottom like mad.
i was thinking of having some nice chrome puts that is cut on an angle and have the tip exiting the rear wheels. i was going to do that. but i didnt have mooney and i would loose alot of clearence from my car.
im just decided im going to have the exhaust exit the just before the rear axle. it should be alot cheaper when i take it to the exhaust shop. dont have to try to bend it over the rear axle and everyting.
if its going to cost memore then ill do it myself.
Old Jan 9, 2008 | 01:05 AM
  #70
pg29's Avatar
Car: 88 GTA
Re: SIDEPIPES
instead of huge stingray-esqe sidepipes, how about a side exit exhaust such as mine? i think it looks alot cleaner on a thirdgen. heres some pics:
no making fun of the VW cause it doesnt have a V8 haha.
Old Jan 9, 2008 | 02:24 AM
  #71
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: SIDEPIPES
Similar to pg29's, I've always liked this look:
Old Jan 9, 2008 | 05:06 AM
  #72
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: SIDEPIPES
Wow... that looks fantastic. But you went through a lot of work to make those look good on the car. Most people are just going to dump them under the gfx and call it a day.
And LOL at your "Fugly" hood. Your reaction was hilarious, not in a bad way. But I HATE those kinds of giant scoop hoods, but damn it works on your car. That's an amazing ride if you ask me. You made a bunch of things work together in a very interesting way and it works real well. I bet it goes even faster than it looks!
I personally like my dumps right near the diff because you cant see the pipes underneath unless you're pretty far away. You guys with the side exits, it looks cool but it's painfully obvious how little ground clearance there is.
My ground clearance aint great, but at least that aint obvious from teh side.
Just an opinion, I dont mean to put down anyone's hard work, but true side pipes are just very difficult ot pull off on these cars and I think side exits look good, but if I were to do them I'd go with some boom tube tips like Skulte's car:
Old Jan 9, 2008 | 02:47 PM
  #73
pg29's Avatar
Car: 88 GTA
Re: SIDEPIPES
yeah i do have to take it easy over speedbumps, and driveways, but its worth the look, the sound, and the power.
Old Jan 9, 2008 | 03:14 PM
  #74
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: SIDEPIPES
A 3rd gen Trans Am (imo) looks more exotic than say a classic American muscle car. I had once seen a clean exotic looking white 3rd gen TA on the street from the front. Driving by it, it had large chrome sidepipes which made me do a double take. Ya, that just killed it for me. Very "hickish" if you ask me. But ya, to each his own.
Old Jan 12, 2008 | 01:28 PM
  #75
AC's Avatar
AC
Re: SIDEPIPES
Boom tubes like Andris' car do look sweet but he and I live in CT where those are CERTAINLY not street legal or emissions passable. His car now from what I understand though is off-road only. I still have to find a way to pass this spring....I'll have to run a fast change 3" cat in my mufflex 4" system, run a lean tune and with a 1/4 tank of 93 dump a half gallon of denatured alchol....then maybe it'll pass.
I really do like that 4th gen look. Sides pipes for me would have to be 100% hidden except where the tips come out but alas...again my SFC's don't allow.
Old Jan 13, 2008 | 05:51 PM
  #76
topradman's Avatar
Car: 91 Z28
Re: SIDEPIPES
HEY INFERNALVORTEX, THANKS FOR THE COMPLIMENT. FIRST TRIP TO THE STRIP YEAR BEFORE LAST ONLY WENT 11.60 WITH STREET TIRE. I WAS SMOKIN OFF THE LINE AND WHEN SHIFTED, CK ENG LIGHT CAME ON (O2'S) AND REVLIMITED OUT AT 6200 SEVERAL HUNDRED FEET FROM THE FINISH, NOT TO MENTION BLOWER BELT SLIP AND HEADERS COMING LOOSE DURING THIS THIRD PASS. (GUESS THAT'S WHY THEY CALL IT "TEST & TUNE". TRANS ISN'T VALVED FOR WOT O/D SHIFT INTO 4TH AND THAT'S PROBABLY A GOOD THING. CAR HAS NO PROBLEM REVING OUT TO THAT. MY MATH SAYS WITH THE NEW TALLER TIRE, AT 6200 RPM THIS CAR SHOULD TOP SPEED AT 205MPH!! PROBABLY WILL NEVER ATTEMPT THIS WITHOUT BEAD LOCK RIMS THOUGH. WITH DRAG SLICKS AND EVERYTHING RIGHT, SHOULD BE IN THE LOW 10'S WITH THIS CAR THIS YEAR. I'LL POST THE RESULTING TIME SLIPS WHEN THE TRACK OPENS FOR TEST AND TUNE IN MARCH I THINK. THANKS AGAIN, TOPRADMAN
Old Jan 16, 2008 | 03:51 PM
  #77
1985transmaro's Avatar
Car: 1985 Camaro-1986 Trans-Am Cross
Engine: 5.0L, Fresh From A Rebuild
Transmission: 700R4 Shift Kit
Axle/Gears: 3.03 Std.
Re: SIDEPIPES
the camaro and the firebird ended their status as muslce cars when they went to a uni-body frame. they are famous for twisting under torque, off topic but it had to be said. more on topic, sidepipes are fo a true muscle car. on a stingray, love them, on a thirdgen, ewwww. just my opinion of course but still...
Old Jan 16, 2008 | 03:55 PM
  #78
Stephen's Avatar
Car: 87 GTA
Re: SIDEPIPES
I guess they were NEVER muscle cars then, since EVERY year, 1967 and up, have been unibody cars.
Old Jan 16, 2008 | 03:56 PM
  #79
Engine: 400
Re: SIDEPIPES
Yep. The 1st gens just had bolt on front subframes. But they have always been unibody cars.
Old Jan 16, 2008 | 04:02 PM
  #80
Stephen's Avatar
Car: 87 GTA
Re: SIDEPIPES
For that matter, that rules out Mustangs, Roadrunners, Superbirds....
Pretty much EVERYTHING but Chevelles, trucks, 60's station wagons & 4 doors....
Old Jan 16, 2008 | 04:12 PM
  #81
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: SIDEPIPES
I can live with the hidden side pipes. i like the boom ones. would like a one molded into the last section of the GFX. especially on my 91. Only thing is what about the SCF!!!!! That is a very important detail to me. can you mold a side pipe into the GFX on a camaro? If so then i'm sold. I thought i hated sidepipes but the hidden ones i like.
Old Jan 16, 2008 | 05:34 PM
  #82
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: SIDEPIPES
I like the side exits better too. I plan on doing something similar to the boomtubes but with a 4th gen Z28 tip which is about the same shape as the tip of the boomtube tip.
Old Jan 17, 2008 | 12:13 PM
  #83
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
Re: SIDEPIPES
its your car man do what you want!!! (IMO) those rear exits in front of the tire you guys have look like horrid not to mention the bottoming out feature that come with them to.and as for the muscle car confusion any 2door car that came factory with a v-8 was considered a muscle car.probley not muscle cars like old vette's or a charger but they were still considered muscle cars.unless they were classed other words.
Old Jan 17, 2008 | 05:27 PM
  #84
89RsPower!'s Avatar
Re: SIDEPIPES
ok.. so what was that dumb unibody comment about? BTW that didn't make much sense.. maybe you don't speak english as a first language or something...
Old Jan 17, 2008 | 07:43 PM
  #85
85 camero's Avatar
Car: 85 berlinetta
Re: SIDEPIPES
u know opinions are like a**holes everyone has one!!!!
Old Jan 17, 2008 | 08:29 PM
  #86
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
Re: SIDEPIPES
well to tell you guys the truth i like them all , the cat back is nice in its own way but the side pipes are nice in theirs , im not very fond of the side exit but its nice in its own to , but like someone else said you have to make it look good , an just for the record a muscle car is what you make it to be , what you call a turbo charged v6 gn or even a firebird or camaro, i call it a muscle car it may not have that distinct v8 sound but i betcha it smokes the tires till they blow , right ?,, well i wish everbody the best in wich ever route they go im sure itll be nice no matter what
Old Jan 17, 2008 | 08:44 PM
  #87
Engine: LO3
Re: SIDEPIPES
What about running them just under the SFC's then use them to mount a hangar? It would work but probably look real ghetto especially if your sfc's are totally visible like mine are.
Old Jan 17, 2008 | 08:54 PM
  #88
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: SIDEPIPES
So if 3rd gens have such bad ground clearance with side pipes or side exit, how do the mustangs (Rousch, Eleanor) get away with it? There has to be some of those guys running SFC's too.
Old Jan 18, 2008 | 05:31 AM
  #89
Car: 1992 Camaro RS
Re: SIDEPIPES
I'm definitely no expert when it comes to this, but I can only make general assumptions.
Possibilities:
1. Thirdgens are lower to the ground than those cars.
or, more likely:
2. Thirdgens are monococque/unibody cars. There are no frame rails. With a lot of those other cars, the body sits on top of a frame. I bet they tuck the exhaust up into the frame, meaning it doesnt affect ground clearance at all.
Old Jan 18, 2008 | 09:10 AM
  #90
Stephen's Avatar
Car: 87 GTA
Re: SIDEPIPES
Possibilities:
or, more likely:
3rd gens do sit lower, but Mustangs are unibody cars too. As are 90% of the muscle cars. Only full-size cars were framed cars. ie: Chevelles, El Caminos....
Old Jan 18, 2008 | 09:26 AM
  #91
Engine: LO3
Re: SIDEPIPES
Yeah I always thought that the 1st gen camaros were frame cars. However, I was watching powerblock tv the other day, and they built a brand new 1st gen from a "crate camaro" unibody from year one.
Old Jan 20, 2008 | 03:16 PM
  #92
Evil Ed's Avatar
Car: 82 Transam
Engine: 305 soon 383
Transmission: auto.
Re: SIDEPIPES
don't know what to think of it
http://www.youtube.com/watch?v=I7omgfV7PXc
http://www.youtube.com/watch?v=Edlf585KZOU
Old Oct 18, 2015 | 08:29 PM
  #93
dthela's Avatar
Car: 1987 Z28 zz440
Engine: ZZ440
Transmission: 5spd
Axle/Gears: 4:11
Re: SIDEPIPES
3rd gen not performance cars? Wanna run me?
Old Oct 18, 2015 | 10:53 PM
  #94
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
Re: SIDEPIPES
Man. I last posted on this thread in 2007! Your comment gave me nostalgia out the *** so thank you. Sadly I don't have my third gen anymore but I do love my goat.
WASyL
Jun 13, 2009 02:42 PM
83 MidniteZ
Feb 19, 2009 08:53 PM
Cammed Kitten
Jul 8, 2004 04:22 AM
silver89Rs
Jun 6, 2002 11:27 AM
NjCamaroCruiser
Mar 24, 2002 10:34 PM
