Long tubes & standard transmissions
Old Nov 5, 2007 | 12:03 PM
tmviper's Avatar
Hey, anyone know what long tube headers will fit on a third gen with a T-56 in it? i have a 700r4 now, but i dont want to put something on there that will close the door of ever having a six speed in my car. if anyone knows of any clearance issues, or ways to fabricate to fit, i'd appreciate it. thanks
Old Nov 5, 2007 | 07:48 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Long tubes & standard transmissions
Dont quote me but I believe the T56 is smaller than the 700R4, I dunno if clearance will be an issue or not, I doubt it.
Old Nov 5, 2007 | 08:25 PM
91L31Lo3's Avatar
Car: 91 camaro, 83 rx7, 07 cbr600rr
Engine: 305, vortec heads
Transmission: t5
i was just looking around on jegs and they have dimensions for the t56 on there
Old Nov 5, 2007 | 08:53 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I run the Hooker 2210s and they clear fine. I did have to trim my K member a little.
Old Nov 6, 2007 | 09:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am also running hooker 2210s and I also had to do some minor clearancing on my Kmember but your motor mounts have a lot to do with this. saggy old mounts means the engine sits lower nd may not require the grinding. I then made my own custom 3" ypipe to clear the tranny.
Old Nov 6, 2007 | 09:57 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
does anyone know if long tubes would fit with a wc t-5?
Old Nov 7, 2007 | 12:49 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
long tubes dont fit for the transmission.. it fits for the bellhousing.. the collectors dont even go past the bellhousing.. and yes, the hooker 2210's will fit with a t-5
Old Nov 7, 2007 | 10:52 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
thanks smart ***! but u have an 84 car so prolly dont have a hydralic set up. u still got the z bar setup?
Old Nov 7, 2007 | 11:03 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
84 Should be hydraulic. 83 was the last year of mechanical. There is a sticky posted at the top of the Exhaust section that covers which headers fit with each engine/transmission combo.
Old Nov 7, 2007 | 11:17 AM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
so thats good then. so they should fit, hooker says that they will fit and trans. i just dont want to spend $700 if they dont fit.
Old Nov 7, 2007 | 11:34 AM
5678TA's Avatar
Car: 1984 Trans Am
sorry to sound like a smart *** but you basically are fitting the headers for the bellhousing.. i got the hydro clutch.. i have to say, the slave is pretty close to the collector flange.. but it works great..
Old Nov 7, 2007 | 01:42 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
all right, thanks for the info. u know i m a auto tech by profession, and most times when u pull a transmission, u pull the bellhousing with it. (not trying to be a jerk). but any way was there fabrication to get those in, i heard its a tight fit.
Old Nov 7, 2007 | 03:31 PM
5678TA's Avatar
Car: 1984 Trans Am
i did have to clearance the k-member on the passenger side like everyone else.. but i got solid motor mounts so i only made about 1/8" clearance..
i hear what you say about pullin the bellhousing.. i usually just yank the tranny only.. having a lakewood bellhousing has too many bolts..
Old Nov 7, 2007 | 05:53 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
well i guess it depends on if ur pulling out a automatic or a manual.
Old Nov 7, 2007 | 06:16 PM
5678TA's Avatar
Car: 1984 Trans Am
ya i only roll with manuals.. i dont have a tranny jack either so i pull it myself.. the bellhousing is another 35lbs that i dont need on the 100lbs trans..
Old Nov 7, 2007 | 07:23 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
i hear that! when i did my clutch last winter i pulled just the trans out, then the bellhousing. its easier to get at the bellhousing bolts if the trans is out.
Old Nov 17, 2007 | 10:36 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Would an aftermarket trans member like UMI's for instance help out the clearance problem for the 2210's? I want LT's for my T/A cause Im not too fond of any of the catbacks for our cars and Im gonna go duels with bullets as opposed to my shorties with a flowmaster..
Old Nov 17, 2007 | 01:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I ended up making my own crossmember for more clearance. There was no aftermarket ones on the market at the time. I still wish Ihad more but it mainly because my car islowered. The UMIO one may gice you more then what you have to play with now but its all up to how low your car is already. You just have to realize that the long tube headerd where not designed to be run on a street car that is low to the ground.
Old Nov 21, 2007 | 05:08 AM
Well my car hasnt been lowered at all.. Do any of you have pics of the 2210's and exactly where it hits the crossmember?? or just pics of how low the headers sit??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
SG91camaro
Sep 5, 2015 10:27 PM
