Hooker 2055's
Old Jan 12, 2008 | 10:47 AM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
Hooker 2055's
i have a 1992 camaro with the L03 in it, with the hooker 2055's fit my car?, and if they wont, what are the next best headers to get?
Old Jan 12, 2008 | 10:58 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Hooker 2055's
they'll fit just fine, and they're the best headers you can get.
Old Jan 12, 2008 | 11:17 AM
Re: Hooker 2055's
if i get the 2055's should i get this to go with it http://www.holley.com/16820HKR.asp , and what would be a good high flow cat to go with it?
Old Jan 12, 2008 | 12:13 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Hooker 2055's
I got some Hooker 2055's installed, a 3" Magnaflow cat & a flowmaster mandrel bent cat back (buy one from a big company, muffler shops don't do mandrel bends)...
Being that the stock cat was longer, I had a spare 3" pipe from Flowmaster that they used...
Also, watch the 2055's kit for some spacers, used to hold the brackets for alt / ac compressor...
Raf
Old Jan 12, 2008 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, you don't want that system.
Get the rest of your parts, including the cat and cat-back, for the '86-'90 TPI single cat application - same as the 2055HKR's.
The Catco 9118 is one such cat. Magnaflow is another cat often mentioned, although I don't know the p/n for it.
Old Jan 15, 2008 | 01:02 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Hooker 2055's
Okay heres an idea for you. Its what I have to do since I need full header back exhaust and e-check to get plates.
I am going to buy the 2055's from Summit, thing is first give them a call and let them know you have a price to beat, Summit sells 2055's for $345 and Jet-Hot sells them for $330, so ask Summit to beat the price and they will go cheaper than $330 instantly...or maybe in a few days...I havent given them the call yet for it..but they will beat the price.
Then since I cant make it to a shop to get the y-pipe done I am buying Hookers y-pipe which is 2.5" out ($240), meaning when I buy my flowmaster I have to buy the kit that tapers down to 2.5" ($355) at the cat to fit, then I will buy whatever cat I feel, like this one from Dynatech (I want to be different, maybe even a better muscle car sound, who knows)
Install everything then go out and get 30 day tags and take it to a shop to have them cut the y-pipe and fit flange and install my cat onto the y-pipe, then have them use the piece they removed from the y-pipe and flange that also and make it into a test pipe, so all I have to do for emissions is unbolt the test pipe bolt the cat in and vwala I have a quick and easy way of getting emissions done. Leave the emissions place and put the test pipe back on...finished.
But thats just me
Hooker 2055 = $329?
Hooker Y-pipe = $240
Flowmaster CB = $355
High Flow Cat = $170
Exhaust Shop Labor = $150 (quote)
TOTAL = $1245
Old Jan 15, 2008 | 01:17 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hooker 2055's
Originally Posted by I H8 WWD
Hooker 2055 = $329? Hooker Y-pipe = $240
The Hooker 2055's come with a Y ($449.99 from Jeg's). Here's a direct-fit 3" system that works very nicely:
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old Jan 15, 2008 | 01:20 PM
luvofjah's Avatar
Re: Hooker 2055's
Yep, I was under the assumption that the 2055's came with the 3" y pipe too... mine did... I actually got mine from Jet Hot for a steal! Guess they were sitting on the shelf too long or taking up space...
Consider getting them coated to protect your investment...
Rafael
Old Jan 15, 2008 | 01:29 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Hooker 2055's
JamesC
Thats for air tubes and painted....add ceramic coating, also that y-pipe is missing the LONG straight piece where the cat goes so you can delete it asap. So theres another reason its cheaper. Less y-pipe and no cermaic coating...
http://store.summitracing.com/partde...5&autoview=sku
Rafael
You got the set with air tubes huh? As thats the ONLY way to get Hookers 3" y-pipe, unless you call them but even then you might not get it, you have to but the air tube hooker headers otherwise you can get the 2.5" y-pipe.
Old Jan 15, 2008 | 01:34 PM
five7kid's Avatar
Not sure what you're trying to say there, but the 2055HKR's come with y-pipe to a 3" cat inlet, and A.I.R. tubes.
Old Jan 15, 2008 | 02:05 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Hooker 2055's
LMAO....wowser, sorry guys I have the 2460's in my head so im getting everything twisted and confused...sorry again.
But luvofjah what PN is that Magnaflow as I might just buy the 2055's get the tubes cut, get the Magnaflow cat and hooker cat-back, so I have a full 3" exhaust.
HERE IS MY QUESTION NOW, does the 2055 with y-pipe and your magnaflow cat hookup without modifications to your exhaust? As I cant start or move my car until the exhaust is on so I need direct fit parts. Please let me know, thanks.
Old Jan 24, 2008 | 03:27 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Hooker 2055's
EDIT: Question Answered
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
