High Flow Cat Question
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Was pulled over by the 5.0 today and looked under my car and noticed that I didn't have a cat. So now I am looking for the highest flow cat that would work with a 3 inch pipe, and I don't need the hose that comes off it either.
This situation sucks
Damn cops!
Damn cops!
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: High Flow Cat Question
Do you need to get it sniffed, or just looked at?
You could always pull out your "test pipe" and get some junkyard catalytic heat shields, maybe the core too, and just drill it out, and weld all that onto your test pipe.
Then it would look like a normal cat to the naked eye, but really be there for decoreation.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
You can get a 3" universal Catco cat without an air tube from summit for about $60. I doubt you'd notice a difference in performance... they probably rob 1-2 Hp max.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
This is the one I'm running... It's a little short and I had to add a 6" length of 3" pipe to bridge the gap, but it's decent for a cheap cat.
CTO-6907
http://store.summitracing.com/partde...0&autoview=sku
CTO-6907
Engine: LO3
The problem with running a cat, is that your car will smell like every other honda on the road. You want that un-cooked muscle car smell out the pipes!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Adam, we dont need to see your huge sig every post, please.
Second, cats are required by law on street cars in all 50 states, and yes they do provide a valuable service in cleaning up the air we breathe. That "uncooked muscle car smell" is raw gasoline and carbon monoxide, which will kill you if you breathe too much of it.
Car: 1988 Camaro
Engine: 383 Stroker
Is the cat co a high flow cat. Because I am looking for the highest flow one out there for my car
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
That's the stock replacement 3" with an air tube... he doesn't want an airtube, so it's gonna have to be a universal fit.
Car: 1988 Camaro
Engine: 383 Stroker
Is the catco 6907 going to be a high flow. it didn't say anything about it on summit's website
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
All cat converters are made the same now.
California won't let them put high flow on the box anymore.
Transmission: 4L80E/4L80E
"Universal" almost always equates to "univerally more expensive than direct-fit by the time you get it installed", especially if you have to make a trip to an exhaust shop for any of the installation.
All aftermarket cats are "high-flow". And today's aftermarket cats are all "no restriction" either, so you can have clean air and horsepower too.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
It comes with a cap on it. Don't want to hook up A.I.R., keep the cap on.
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
What about a test pipe?
And illl pass emissions check it only takes an extra $15 20
Car: 1988 Camaro
Engine: 383 Stroker
You dont lose 20 hp with a high flow cat do you?
When I go to the track I will have 2 cutouts on each side of the y pipe, so I dont think it would matter that much
Car: '87 Iroc-Z
isnt a gutted cat just as good as a hiflow cat?
I mean since there is nothing insise the gutted?
Car: 1988 Camaro
Engine: 383 Stroker
Does anyone know how much power you would lose with a high flow cat.
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
random technology are top of the line and flow the best, but they are like $400, catco cats are ok but not top of the line, a dynomax would also be pretty decent for the price
Ok Mr. Expert, where do you rank Magnaflow cats then?
Car: '87 Iroc-Z
Car: '86 Iroc Z
I've been told that there is really no such thing as a "high flow" cat. They're all made to meet spec. One company doesn't pack it full of bullsh!t and make a "less flowing" cat lol. Yes, even the almighty magnaflow cats are made to meet spec. As far as the story about getting pulled over, your car must have reaked of gasoline or been louder than hell because I live near Minneapolis, not too far from Wisconsin, and I can't imagine a cop looking under my car or even talking about emissions.
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
