headers without a.i.r.
Old Jun 4, 2008 | 11:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm on a very low budget and came across a set of non-air headers for my 89 iroc, what all needs to be done to get rid of the a.i.r. system?
Old Jun 5, 2008 | 01:55 AM
Pocket's Avatar
Car: 91 Trans Am
Re: headers without a.i.r.
Just remove it
Have you budgeted in for an exhaust shop to connect the headers to the rear exhaust?
Good gaskets?
Good bolts?
Starter shield?
Things that can go wrong? Broke dipstick, sheared manifold bolts, bad cat, broke knock sensor, etc
Old Jun 6, 2008 | 01:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you read the sticky post at the top about removing the AIR system?
Are you aware that removing the AIR system on a street vehicle in the United States is a violation of federal emissions laws, even if your area doesnt do emissions tests? I know some parts of New Jersey have strict emissions tests like California, so be careful.
Old Jun 6, 2008 | 03:15 PM
89RsPower!'s Avatar
missed the sticky.. oops.. I know, I've never had em open the hood at the inpsection station though.. just needs to be able to pass the sniffer and saftey..
Old Jun 8, 2008 | 09:32 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Seriously Kevin do you have to jump in every thread that has to do with emissions and remind everyone that's it's "violation of federal emissions laws", your like the smog police of the boards
I'am pretty sure people know what there doing and the risks they take when removing emissions equipment on their vehicle and there probably more worried about getting a speeding ticket then any fine for not having a AIR system on the car.
Old Jun 8, 2008 | 09:42 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
you would be suprised how many people are un-aware of the fact! CHILL OUT
Old Jun 8, 2008 | 09:58 PM
Tony89GTA's Avatar
Car: 89 GTA
You be surprised how many people play dumb
Old Jun 8, 2008 | 10:41 PM
Old Jun 8, 2008 | 10:45 PM
89RsPower!'s Avatar
Although I'm sure it happens, I've never heard of or known anyone who has received a fine for removing their emissions equipment, I've heard of shops being fined, but never an individual. Around here if you have an inspection sticker you're good. Cops don't pull you over and check your car over for compliance. Most of them wouldn't know it ever had an A.I.R. system to begin with. Aside from a cat. conv. most people at the inspection station around here wouldn't have a clue if there were missing emissions components.
Old Jun 8, 2008 | 10:51 PM
89RsPower!'s Avatar
What I really need to know is this: Can I reroute the belt and keep my A/C without a delete pulley or switch to a shorter belt or something or is a delete pulley absoluetely nessicary with a serp setup and a/c?
Old Jun 8, 2008 | 10:54 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You can get a shorter belt and reroute, if you don't want the smog delete pulley. That's the way mine is setup, although I'm not sure what length belt you will need - the previous owner did it. Here's how mine is routed:
Old Jun 8, 2008 | 11:52 PM
around here you almost always are told to "pop your hood" if you are pulled over, expecially by the CHP. they check everything from ride height to carb e.o. tags .dam imports ruien it for everyone
Old Jun 9, 2008 | 01:52 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
That's because it's the people's republic of kalifornia
Still, if you get non-air headers, and do a clean job (no obvious unplugged wires/hoses hanging all over the place), I bet most wouldn't even notice. I doubt every inspector is gonna know every car that came with air injection, but he will definitely spot disconnected stuff.
Old Jun 10, 2008 | 01:34 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
You know you have the right to say no right? police are not allowed to search your vehicle without a warrant or suspicion beyond reasonable doubt. It's your 4th amendment.
Old Jun 10, 2008 | 01:52 AM
absolutly not, wel you do but probable cause here is them suspecting you were "racing". if you hassle them too much, they will impound your car. do you watch the news? they CRUSH cars here for racing .i like oregon, i graduated from NEWPORT HIGH.
Old Jun 10, 2008 | 10:54 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
wow, another reason, besides all the tree hugging liberals, not to live in ca.
Old Jun 10, 2008 | 11:03 AM
yah, you could see everything you could think of in CA. good and bad. its kinda like a little slice of heaven and hell
Old Jun 10, 2008 | 01:17 PM
Tony89GTA's Avatar
Car: 89 GTA
ROFLMAO
Old Jun 10, 2008 | 01:45 PM
whats "ROFLMAO" mean?
Old Jun 10, 2008 | 02:22 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
Axle/Gears: 7.5 3.23 mini spooled
Rolling On The Floor Laughing My A$$ Off
Old Jun 10, 2008 | 02:37 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Funny I read this post and knew it was from you (before I saw your name)
Old Jun 10, 2008 | 02:47 PM
DCOWBOYS1975's Avatar
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
Our cars with or without cats are going to hurt the air. So if your concern is for the environment so much why drive a hot rod?? Not trying to start a fight but I just don't get it.
Old Jun 13, 2008 | 10:57 PM
Kevin91Z's Avatar
Yes, I have to. I am trying to educate people that you dont have to hack up your car and remove everything to make it perform. In fact, 95% of the people who post questions asking about removing stuff have slower cars than I do. And I pass CA's tough emissions test as clean as stock, get 25 miles per gallon, and drive my car every day. Until someone can post up their car with similar mods running faster and getting better MPG than we are in SoCal, without their emissions devices, I'll keep posting trying to educate people. There are lawmakers out there trying to keep us from modifying our cars AT ALL. And the more people out there running illegally, it gives them more ammunition to write tougher laws restricting what we can and cant do with our vehicles. I dont want that any more than you do. It IS possible to have a clean-running car and still make 400+ horsepower.
Old Jun 13, 2008 | 11:28 PM
Stephen's Avatar
Car: 87 GTA
With the 08 ZO6 putting 500 hp out CLEAN, we have no excuse for our 250-400 hp cars, not having the required equipment.
When I bought my 87 GTA, at 160,000 miles, the smog pump pulley was gone. The pump itselfwas still there, the AIR tubes still on, so everything LOOKED good. But it had a brand new cat on but doesn't even have the AIR tube connection.
Thanks to the new cat (Magnaflow), my emissions tests were virtually zero.... Some WERE zero!
High Speed-2692rpm
HC 220-standard 4-my reading
CO% 1.20-standard 0-my reading
Idle
HC 220-standard 16-my reading
CO% 1.20-standard 0.01-my reading
So, despite my car not being visually "legal", my good cat takes care of everything.
Old Jun 14, 2008 | 07:18 AM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Don't get me started on Commiefornia. (Born and raised there, then got the heck out--just call me a naturalized Texan. Excuse me while I go clean my AR15s and M16.)
Kevin91Z,
Fess up, if the pollution police out there didn't require you to have all that crap, would it be on your car?
Old Jun 14, 2008 | 01:10 PM
Tony89GTA's Avatar
Car: 89 GTA
Ah people do it for other reasons then just performance and I wouldn't call it a hack job, and no removing a cat or air system is not going to make your milage worse. Also it's not just people with performance cars that do these things but law makers are going to **** on you anyways for just having a fast car. Let me ask you this you going to follow the law if they say you have to return you car to stock? Sorry man but the more laws they make the more people will break them.
Old Jun 14, 2008 | 08:32 PM
Kevin91Z's Avatar
If I didnt have to smog anymore, I'd be on the phone with Holley ordering a StealthRam, which removes only the EGR. Then I'd dyno test it to see if its better than my siamesed runners I have now, and keep whichever is better. I'd still keep the cats and the air pump, because they're not in my way and they do help.
Most of the posts I see about people asking about cat removal are doing it because their neighbor Billy-Bob told them they'd gain 100 horsepower if they did. Its true that the cats from the 70's and 80's are horrible and do rob you of 10 horsepower or more. However, today's aftermarket "high-flow" cats are tons better and you might lose 1 or 2 horsepower. You can make that up by removing the crap in your back seat and/or your trunk and saving weight. As far as the AIR pump, I see people posting about removing that because they're cheaping out with headers that dont have the AIR tubes, and they want easier access to the spark plugs. That's not a performance gain, that's just laziness and cheapness, in my opinion. (putting on flame suit)
Old Jun 15, 2008 | 11:35 AM
89RsPower!'s Avatar
Wow didn't mean to start all this, just wanted to know how to reroute the belt without the pump, I didn't look to hard at that but would that also require a standard rotation pump? If so that would be perfect because I already have one laying around and I'm broke and I really need to finish this swap. As far as the headers go I'd never buy headers with a.i.r. tubes or for free if I could get non air headers. They look like crap, get in the way, and only function while the car is cold and make no difference on a warmed up car.
Old Jun 15, 2008 | 12:18 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
"Billy-Bob?" Hmmmm.. -Bill
Old Jun 15, 2008 | 02:16 PM
Tony89GTA's Avatar
Car: 89 GTA
True for most people taking off the cat is probably not going to do much but man the AIR pump and having AIR tubes on the headers is the gayest thing going lol. Anyways kevin just busting your *****
Old Jun 15, 2008 | 03:15 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i think you might be misinformed. If its like here in Canada, the police cant make you pop your hood, however the DOT guys can inspect every inch of your vehicle without a warrant, as far as safety/emissions equipment goes.
So if you **** off a cop they just call in a transportation cop
Old Jun 15, 2008 | 05:00 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
If you refuse, guess what you instill in the cop? If you said "suspicion" ding ding ding! You're right.
If you're a law abiding citizen, you have nothing to be afraid of, so you let the cop look. When you refuse, it makes him think you're hiding something from him. Then he can arrest you and search your car to his hearts content. Better hope the previous owner didn't drop a doobie in the center console, because if he did, YOU'RE GOING TO JAIL!
People believe everything they read on the internet from anybody. Ask a cop what he is and isn't allowed to do next time you get pulled over. They're allowed to do quite a lot.
Edit: Also, I just passed emissions with my factory-stock car. With 137k. Factory cat, air pump, egr, vapor canister. Everything except the O2 sensor was the same piece the car came with. Granted, I squeaked by (145/220 HC Load, 1.19/1.20 CO Load / 207/220 HC Idle, .69/1.20 CO Idle) but it was with factory everything. And bad valve guide seals.
Old Jun 15, 2008 | 05:18 PM
Tony89GTA's Avatar
Car: 89 GTA
If you're a law abiding citizen that should give you more reason not to let him search your car.
Old Jun 17, 2008 | 01:04 AM
Kevin91Z's Avatar
I dunno, I think this is pretty sexy:
Old Jun 17, 2008 | 07:25 AM
Engine: 350 Crate
I agree. And I have not always been a stand up citizen. In fact I probably know more about the law than most cops. They cannot search any compartment that has to be unlatched or unlocked i.e. trunk, glove box or the area in the back as long as it is locked. And come on, they are not going to cal DOT to come inspect your car unless you got pulled over for something real serious. And I could have 400+ HP if I had a supercharger too.
Old Jun 17, 2008 | 09:28 AM
Stephen's Avatar
Car: 87 GTA
What headers are those? I see the A.I.R. tubes...I see they aren't hooked up, then I see ANOTHER A.I.R. tube (apparently) connection to 1 tube, hooked up the the intake manifold base..
Old Jun 17, 2008 | 10:28 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
The "other AIR tube" is actually for EGR. I think it's the corvette style external EGR for heads that don't have the internal passages.
Old Jun 20, 2008 | 02:52 AM
Kevin91Z's Avatar
Yes, that is my previous engine from 2002, and those are Dyno Don's original headers we modified to work with my L98 Corvette heads, to provide the EGR function like the Corvettes do. I couldnt find any pics of my current setup.
Johnny*G
Oct 20, 2015 12:37 PM
NZKnight
Oct 15, 2015 02:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
