Hooker headers
Old Jul 23, 2008 | 06:53 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Hooker headers
I was looking into buying a set of hooker 2055's but it looks to include a y pipe for a single cat only. Where can I get a decent header & y pipe combo for less than $500? It needs to bolt to a dual cat set-up for an 89 firebird.
Old Jul 23, 2008 | 11:33 PM
cityspud117's Avatar
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
Re: Hooker headers
someone correct me if im wrong but i think that 89 was the first year they made dual cats for that car and it was an option (N10)...best bet is to do a search and if you don't find anything just order a set of headers you want like the 2055's without the y pipe and get your own made at a muffler shop...
Old Jul 24, 2008 | 12:17 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Hooker headers
Old Jul 24, 2008 | 07:23 AM
all4u's Avatar
Car: Firechicken
Re: Hooker headers
I saw a Y pipe in jegs catalog for $230 in their tpi section. Whould this be a good one cause my muffler shop is expensive to fabricate stuff, so would it be ok to use the jegs one? Thanks for everyone's help.
Old Jul 24, 2008 | 05:47 PM
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
Re: Hooker headers
you need to check to make sure it will fit the headers you want...for example if you want the 2055's they will only fit the Y pipe that hooker makes, unless you get a custom one made...for $230 you should be able to get a Y pipe made at meineke even for less than that. Id have to see a link to the Y pipe your talking about but most likely its a no go on it...
Mike
Old Jul 25, 2008 | 09:02 AM
all4u's Avatar
Car: Firechicken
Re: Hooker headers
So what headers should I go with that will give me some mid range torque and great sound? What diameter y pipe should I go with?
Old Jul 25, 2008 | 11:27 AM
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
Re: Hooker headers
a lot of guys on here like the hooker 2055's and its been said they are the best mass produced headers for our third gens...you want the Y pipe to be 3"...i forget off hand the size made but it will hook up to a 3" Y pipe i know that for a fact...Long tubes are the best but require lots of fabrication and tru dual exhaust...if you can get a hold of Dyno Don hes on many of the exhaust forum posts he custom makes headers and y pipes you could get a hold of him and work something out...other than that i like my 2055s...they really opened my car up!!!sounds great too especially if you have a cut out before the cat...
Old Jul 25, 2008 | 12:12 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Hooker headers
After reading all the opinions on this board, I got the Hooker 2055's, and they have a very restrictive "collector" outlet (under 2" on both sides!), and are also 1-5/8 Dia. primary tubes. Dyno Don's are more expensive, but are 1-3/4 primaries and have a much less restrictive "collector", plus he can do dual-cat "Y" Pipes.
He hand-makes them, so they take a lot of time and are expensive, but they also work with Vortec and Edelbrock E-tech (raised port) heads as well. On my Hookers, I have to take the headers off to get a few spark plugs out because of my E-tec heads. It depends on your future plans for the car, but I've spend a lot of time kicking myself for not buying Dyno Dons headers. Just my 2Cents.
TA
Old Jul 26, 2008 | 11:44 AM
all4u's Avatar
Car: Firechicken
Re: Hooker headers
What's the best way of contacting Dyno Don? Does he have a website or does he just do work out of his garage? Thanks for the help guys, you can always be counted on!
Old Jul 26, 2008 | 05:31 PM
Car: 91' z28
Engine: rebuilt 350
Transmission: stock
Axle/Gears: stock
Re: Hooker headers
just type in dyno don in the search box and you'll find him...
Old Jul 26, 2008 | 09:46 PM
all4u's Avatar
Car: Firechicken
Re: Hooker headers
Thanks, I sent him a PM and he replied back. Does anyone else use his headers and how did they work out? Thanks for everything!
redformula88
Oct 14, 2015 06:08 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
