how do u get exhausts together?
Old Nov 22, 2008 | 11:01 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have to redo my exhaust and i have currently headers 2 straight pipes out force exhaust mufflers. the mufflers drag everything and i got me sum dmax race mufflers. i gotta cut the mufflers off and now my pipes gna be short. (im having it stop under car before axle. and i was wondering ho i can get my pipe longer without redoing the whole thing? i have 2 1/4 running back to the mufflers and the mufflers are 2 1/2. any help is appreciated
Old Nov 22, 2008 | 02:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how do u get exhausts together?
buy short lenght of whatever tubing you need, with a bell on one end, and clamp them on?
Old Nov 22, 2008 | 03:52 PM
Engine: 355
can i use a reducer and weld it flush with one pipe and have the other slip in?
Old Nov 22, 2008 | 05:29 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Weld
Clamp
Exhaust shop
Any of those three will work.
Old Nov 22, 2008 | 05:43 PM
Engine: 355
so i can weld the collector that matches flush with the muffler and itd be fine?
Old Nov 22, 2008 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if it fits, sure you can weld anything to it.
Old Nov 22, 2008 | 06:26 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
you need 3 things
1.) a welder
2.) a hammer
3.) case of beer
combine those together and eventually you'll be all set. That being said any set of duals that you run is gonna hang low and probably get smashed, fairly quickly
Old Nov 22, 2008 | 07:24 PM
Civerus's Avatar
4 words, You Can Weld Anything, use your imagination.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
