LongTube Help!!!
Old Dec 4, 2008 | 05:45 PM
89IROCK's Avatar
Car: 89 Iroc-z
Engine: 355, Mini Ram
Transmission: 700R4, 3000 stall
Axle/Gears: BW 9 bolt, 4.11's
LongTube Help!!!
Spark plug is hitting on long tube. I got a shorty plug in too. Pro Comp Aftermarket angle heads. Will post pictures. Engine is removed from car What would you do now?
http://www.cardomain.com/ride/2396914
Old Dec 4, 2008 | 06:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: LongTube Help!!!
Use shorter plugs if there are any, or different headers or different heads.
Old Dec 4, 2008 | 06:09 PM
89IROCK's Avatar
Car: 89 Iroc-z
i got the shorties plugs for the heads. The headers are new and so are the heads so it be pointless to changes heads just for exhaust. what about heating it up and trying to move the tube of the spark plug?
Old Dec 4, 2008 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hoe bad is it hitting? if its just touching, the only option you have is to dent the tube and put a thermal boot/sock over the plug boot.
Old Dec 5, 2008 | 08:14 AM
89IROCK's Avatar
Car: 89 Iroc-z
Got some pictures for you guys.
I bought this header off summit, install and saw the problem so i called them and they told me i got the right headers for the car and for angle GM heads.
Old Dec 5, 2008 | 11:49 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Your heads are not GM. They are a GM based head. But companies move things arond to get the heads flowing better. I'd try a new brand. The cheapest headers is not ususally the best route.
Old Dec 5, 2008 | 12:00 PM
89IROCK's Avatar
Car: 89 Iroc-z
yeah i know they are not GM heads, i guess i miss read summits website. it said will fit GM angled heads so i tho since my heads are for a L98 they would work. but yeah they are cheap headers about 150.00 bucks. I'm not in the mood to throw more money in to headers right now. can i run a spacer like a flange and heat the tube like crazy and move it?
Old Dec 5, 2008 | 01:33 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
If you want to stick with what you have, I suggest you double up on header gaskets (2 per side), which will buy you a bit of space, then you will need to dimple the header tube where the spark plug hits and run some kind of heat sleeve on the plug boot. This will look crappy, but have no measurable effect on power (unless you go nuts) If you heat it, it will mash a large area and look smoother, if you do it cold it mashes a smaller area.
Another option would be to cut out the section, modify it and weld it back in where it gives plug clearance. Your headers are not coated, so this would be the cleanest way to go, and unless you make a mess, will also have no real-world effect on power.
TA
Old Dec 5, 2008 | 01:38 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
TA
agreed.
Old Dec 5, 2008 | 03:01 PM
89IROCK's Avatar
Car: 89 Iroc-z
Hey thanks guys for the ideas i think i will take it to my work so we can cut and weld in up.
1984HO
Mar 19, 2021 11:59 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
tzweelz
Oct 10, 2000 08:34 PM
