Advice on best setup
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Alright, got an LG4 305 1985 Firebird that I just found out needs a new exhaust to pass inspection. This is a good opportunity to get something with better performance so I need advice.
I need a setup that will be interchangable with a 350 from the 305 when I swap it later on. I'm looking to go headers back and yes I'm on a budget. I almost bought a 2.5" setup but I held off because I'm not sure if a 3" is a waste of money or worth it. It's going to be a single cat setup that I don't plan on dumping before the axle.
I'd like something deep, throaty, and loud without the shitty sound when I let off the throttle like I hear on some cars. As far as muffler, I've thought about the Hooker Aerochamber but I'm not sure. Note for the headers, I'll probably keep the A.I.R. tubes.
HELP please!
Oh, if you want to hear my current exhaust here's a link.... http://www.youtube.com/watch?v=hegdVDHNiRw
HELP please!
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Advice on best setup
3" pipe with headers is loud and way overkill for a 305. You'll need a 350+ HP 350 to begin justifying a 3" system. Too big a pipe, not enough velocity in the system.
Can't speak to the Aerochamber mufflers other than they look like Flowmasters that I don't like.
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Well, not really because after reading the sticky on backflow I decided go for a 3" exhaust. The backflow sticky includes what looks to be a qualified comment that a 3" exhaust won't kill an LG4. Besides, everyone with an LG4 eventually does somekind of power upgrade, right?
Firebird Mess85, I think you ought to go for it https://www.thirdgen.org/forums/exha...5-16823-a.html
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
And at 325hp (sometimes less), a 3" exhaust starts to become a restriction at the top end.
Sounds like a 3" is the concensous? What am I looking for when it comes to headers as far as dimentions as same for the y-pipe? Go for a 3" collector and 3" y-pipe?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Hooker 2055's or even Hedmans, same as we recommend for most everyone else.
You definitely want a 3" cat-back for any 305 or 350 engine.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
a good set of shorty headers with the air tubes, along with a 3 inch catback and a cat converter would set you up pretty good. Don't waste your money with a 2.5, you will see results with a 3 inch and are setup if you ever want to do more modding on your 305 or jump to something a little better.
Whats it mean when a header description says "requires head pipe fabrication"?
Is there anything to note on the heads that might be different?
Head-pipe modification means you'll need to weld it up where the y-pipe meets the i-pipe.
The 2055's come with a single cat y-pipe. Yes it will fit with single cat 91-92's with a little modification, as above. But Tony you want to get Dyno Don's headers and convert to dual cats for more flow.
Small block chevy heads from Gen1 engines (not LT1's and not LS1's) are the same. 99% of headers made for thirdgens will bolt up just fine.
