2055's available WITHOUT AIR?
Old 04-01-2009, 08:50 PM
_87GTA_'s Avatar
I tried the search :P
Do 2055 come with the option of AIR delete?
Thanks!
Old 04-01-2009, 09:06 PM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Re: 2055's available WITHOUT AIR?
No.
Old 04-01-2009, 09:13 PM
_87GTA_'s Avatar
Are these tubes removable, like the original manifold AIR tubes?
Old 04-01-2009, 09:29 PM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
No you have to cut them off and then weld up the primary tubes.
Old 04-02-2009, 11:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The Hooker headers without AIR are the part number 2460's, but they do not come with a y-pipe. And the y-pipe for the 2460's is not as good of a design as the one that comes with the 2055's. So its your choice. And remember, removing the AIR tubes on a street car is a violation of federal law, regardless whether or not your state does testing.
I'd stick with the 2055's or send an email or PM to Dyno Don and get his 1 3/4" headers.
Old 04-02-2009, 04:13 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Quick question Kevin91Z, does Dyno Don make headers without air tubes? In the "far" future i might need to upgrade the 2055s.
Old 04-02-2009, 06:33 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally Posted by Kevin91Z
The Hooker headers without AIR are the part number 2460's...
Not exactly. They're both shorties, and both made by Hooker, but they aren't the same headers. Different flange, different collector, different collector connection, different gauge tubes, etc.
Old 04-03-2009, 01:46 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
they come with a pre welded 02 bung correct?
Old 04-03-2009, 02:28 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
are the air tubes on the 2055's where your o2 sensor goes and if thats not what they're for what are they for?. I'm really considering this set.
Old 04-03-2009, 02:53 PM
TheMuskr's Avatar
A.I.R. is a system that injects air into the headers and cat to lower the emissions level if I understand correct
Old 04-03-2009, 04:53 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Look in the pic above! The air tubes are on top of the primary tube, the o2 on the collector.
Old 04-03-2009, 07:09 PM
5speed's Avatar
Car: 86 IROC
Transmission: 5 speed
Axle/Gears: limited slip
I wouldn't wait to long..I just tried to order a set of 2055's and the speed shop told me their distributor can't get any hooker headers...they might be going the way of crane cams...
Old 04-03-2009, 07:15 PM
Stephen's Avatar
Car: 87 GTA
Yes. Dyno Don offers his (the SAME headers), both with or without the AIR tubes on them. The AIR tubes are simply an option on his headers.
Old 04-03-2009, 09:17 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Oh i already got the hookers so no worry there (should get them on the car monday!!). I was stating i might need to upgrade to dyno dons in the far future. I hope hooker doesn't go under, isn't holley the "same" company as hooker?
Old 04-04-2009, 12:24 AM
five7kid's Avatar
Engine: LS1/LQ4
Summit says they'll ship you a set Monday.
Hooker is owned by Holley. The Hooker website is www.holley.com.
Old 04-04-2009, 07:31 PM
5speed's Avatar
Car: 86 IROC
Jet Hot will too..but after the exchange rate, shipping fee, broker fee, duty..those $800 headers will cost me $1400 or so...
db057
04-28-2019 07:45 AM
83 Crossfire TA
01-03-2016 01:26 PM
Bubbajones_ya
09-14-2015 08:38 PM
edoff13
09-11-2015 03:55 AM
scotrans am
09-05-2015 04:26 AM
Quick Reply: 2055's available WITHOUT AIR?
