exhaust question
Old Apr 25, 2009 | 03:42 PM
bunnyfoofoo13's Avatar
exhaust question
the z28 and the iroc came with a y-pipe correct me if im wrong. now i want it to be a straight pipe or run with a mid pipe. basically i dont want the y-pipe. can any one fill me in on what to do.
Old Apr 25, 2009 | 03:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: exhaust question
I'm somewhat confused (normal state of affairs). If you have no Y pipe, there's nothing to bolt to the exhaust manifolds.
The two pipes bolt to the manifolds and are routed downward where they join into a Y. The cat bolts/slips on, then there's the cat back.
JamesC
Old Apr 25, 2009 | 06:45 PM
yes but lets see, i want two straight pipes from headers to tail pipe example like a mustangs exhaust. im not sure if you know what i mean but thats the best i can explain it
Old Apr 25, 2009 | 07:02 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
2 straight pipes all the way out the back of the car from the manifolds/headers is a TRUE 'dual exhaust'. Not impossible to do on our cars, but not the easiest either AND plenty of go-fast cars on this board run a single exhaust out the back roughly the size of a sewer pipe
Old Apr 25, 2009 | 07:34 PM
JamesC's Avatar
I finally understand. I'm sure a shop can fab what you need, though the cost may be prohibitive.
JamesC
Old Apr 26, 2009 | 07:44 AM
that actually sounds really cool. so what are you telling me that mabe i should just stick with y-pipe and if so what is the biggest the pipe can go from header to tail 3, 2.5in
Old Apr 26, 2009 | 07:53 AM
JamesC's Avatar
...mabe i should just stick with y-pipe and if so what is the biggest the pipe can go from header to tail 3, 2.5in
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
JamesC
Old Apr 26, 2009 | 08:00 AM
what about after market
Old Apr 26, 2009 | 08:09 AM
JamesC's Avatar
To my knowledge, there is no performance Y pipe sold that will bolt to an OE exhaust manifold. With a set of headers, such as the Hooker 2055's or Dyno Don's, yes. The Hookers are 3". The following would provide a 3-system:
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old Apr 26, 2009 | 08:56 AM
hm im not to sure. i think i still want to go with a true dual setup i just need to find out how ha.
Old Apr 26, 2009 | 09:23 AM
JamesC's Avatar
i think i still want to go with a true dual setup i just need to find out how.
Check the stick at the top of the page for some ideas. Good luck.
JamesC
Old Apr 27, 2009 | 01:51 PM
JamesC's Avatar
I stumbled on the following link, which I thought might interest you:
https://www.thirdgen.org/forums/exha...ms-solved.html
JamesC
Old Apr 27, 2009 | 02:09 PM
james you are a big help thanks lol no really like that does make it easyier you have no idea now its time to do my reserch.
Old Apr 29, 2009 | 06:04 PM
F41eatsFords's Avatar
82-83 305 Crossfire
88 350 L98 (VIN 8)
JamesC
I may be heading to a slavage yard in a couple weeks, and i was wondering; does the 2 1/4 outlet manifold-3" y-pipe require the 2 1/4 manifolds, or can they bolt up fairly well with little fabrication to the 2" outlet manifolds. I need a new exhaust, and I figure, if I have to swap the manifolds, it's not worth it, but if it's easy enough to bolt on, upgrading to a 3" pipe now wold save me some money in the long run. Anybody know if they do just bolt up? Thanks a lot!
Old Apr 29, 2009 | 06:28 PM
JamesC's Avatar
Originally Posted by F41eatsFords
I may be heading to a slavage yard in a couple weeks, and i was wondering; does the 2 1/4 outlet manifold-3" y-pipe require the 2 1/4 manifolds...
Yes.
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
