Exhaust problems.
Old Jun 12, 2009 | 02:27 PM
poizonpyo's Avatar
Car: '89 Firebird
Engine: 5.7L 350 TPI
Transmission: Auto :/
Exhaust problems.
Alright so I'm driving my 89 firebird 350 TPI the other day and all of a sudden the muffler is dragging on the ground. I looked under and found that the pipe that connects to the muffler is badly rusted and broke off. I am assuming the exhaust system is stock. I wanted to replace the whole thing at some point in the future, but now it seems like it would be better to do it all now. I'm looking for some advice on purchasing a new system (headers included). I was thinking magnaflow catback and edlebrock headers. Any and all input is helpful.
Old Jun 12, 2009 | 02:52 PM
FoodStampsz's Avatar
Car: 86 F-bird TA
Engine: 383
Axle/Gears: 4.10
Re: Exhaust problems.
That all depends... were you looking to go loud? high flow or trying to just replace it? Also depends on the headers your trying to get long or short and how much your willing to drop usually between $500-$1200 for a mild full exhaust system, headers, cats, pipes mufflers etc.
Old Jun 12, 2009 | 03:27 PM
poizonpyo's Avatar
Car: '89 Firebird
I was hoping to find a nice balance between loud and performance...I know basically nothing about headers so i don't know the difference between short or long pipe. I have another car that I'm driving now so it doesn't need to get done right away. I also don't mind spending money as long as I'm getting quality parts. Form the short amount of time I spent looking at prices, I was quessing $5-600 on headers and about 3-450 on the rest (cat, pipes, muffler, clamps, etc.)
Old Jun 12, 2009 | 03:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following will fit your requirements: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
The above is a direct-fit, three-inch system. Hooker headers are a board favorite. The sound of the above is tame at cruise, allowing conversation and music at a reasonable level. At WOT, however, the snarl is nasty enough.
JamesC
Old Jun 12, 2009 | 03:45 PM
racethesunlive's Avatar
Car: '92 Camaro
I'd have to say for headers and Y Hooker 2055's are a pretty solid choice.
For the catback system you should really check out this sticky https://www.thirdgen.org/forums/exha...tart-here.html and see which system you prefer.
Old Jun 12, 2009 | 07:24 PM
poizonpyo's Avatar
Car: '89 Firebird
What exactly is the difference between:
http://www.summitracing.com/parts/HOK-2055HKR/
and
http://www.summitracing.com/parts/HOK-2055-1HKR/
other than one is ceramic coated. Is it worth it to spend the extra $350?
I'm also thinking about a flowmaster 40 series cat system. Anyone have anyt comments about those?
Old Jun 12, 2009 | 07:43 PM
Car: 86 F-bird TA
Engine: 383
Axle/Gears: 4.10
I would save the $350 and go with the 20055HKR you can always wrap em or do whatev not worth spending that amount of money if you are planning a fairly stock exhaust. Also my personal opinion is flowmaster sucks and it is a very heated debate on this forum. Personally go get the headers and go to an exhaust shop and shop around for a true dual exhaust. That way it sounds great and your saving yourself the frustration, based on what you said prior I recommend dynomax. I've never seen anything but great things from them and they are cheaper and have a pretty custom set of exhaust systems depending on what you need.
Old Jun 12, 2009 | 09:07 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Magnaflow ftw !!! Really if you plan to just keep the motor stock and just drive it whatever sound you like the best will be what you should get! Headers i would say either the hooker shortys and y or the hedman shortys and y!
Old Jun 12, 2009 | 09:17 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
cruse the net for a cheap hooker 2055 with y pipe. i got mine for 150.00 and then had it coated.
looked around and found a 3 inch internal diameter cat - but mine has to be cal smog approved - called carb. as are the headers.
i payed 80.00 for a 31 inch 3 inch internal diameter chamber exhaust for the center pipe.
the entire thing including headers was less than 400.00.
Old Jun 25, 2009 | 12:25 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Lots of good info here, and you're really fortunate to have another
vehicle while trying to slay this dragon.
The Hooker 2055 system is solid & has a good rep here on the board.
2064's are an alternative, if you want to get into removing the air pump
and plumbing -- and upgrade the cat to one w/out the air inlet.
Raw headers dump LOTS of heat into the engine compartment. So plan
on some form of insulation (coating, wrapping, or both) for either
type of header. I went with e-bay used ones, then Jet-Hots best
thermal coating applied. Since I want to be able to set on Houston
freeways in august with the a-c on, I'm also going to insulation wrap.
Muffler selection is more of a personal issue w/ respect to you're
preference: max performance (i.e. LOUD), or good performance
but quiter. If you take your time, do lots of reading/research (especially
this forum, I think the budget you're allowing can produce something
nice, that you'll be happy with.
Good luck,
kk
Old Jun 25, 2009 | 12:38 PM
Stephen's Avatar
Car: 87 GTA
I have a Texas Speed & Performance Rumbler (bullet style Magnaflow muffler) LS1 cat-back.
At cruise & light throttle, it is there, but quiet & not annoying in the least. But when you open throttle.....
It comes to life & really lets the neighbors know its there.
https://www.thirdgen.org/forums/exha...r-its-way.html
Old Jun 25, 2009 | 01:18 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My setup
Hooker Headers #2055
Magnaflow Catalytic Converter #94109
Magnaflow Cat-Back #16829
Said to be suttle like a virgin when idle and a crazy **** at WOT. Check out some sound clips, it will help a lot.
P.S. I think I should have got a longer catalytic converter for a full bolt on system. Oh well. I think I'm 10" short between the outlet of the cat and inlet of the cat-back system.
Old Jul 6, 2009 | 04:55 PM
poizonpyo's Avatar
Car: '89 Firebird
Thanks to all for your help. I haven't really had time to do much searching, as I have been busy. The car was at my mechanic about a week ago for an oil change and to replace a little hose that runs next to the oil filter that was leaking antifreeze (my dad and I got the old one off but could not get the new hose on). I asked him about the exhaust situation and he said that in order to pass MA state inspection the exhaust system would need to be OEM or an equivalent.
No person shall operate a motor vehicle on any way which motor vehicle is equipped (1) with a muffler from which the baffle plates, screens or other original internal parts have been removed and not replaced; or (2) with an exhaust system which has been modified in a manner which will amplify or increase the noise emitted by the exhaust. ( http://www.mass.gov/legis/laws/mgl/90-16.htm )
I was just wondering exactly what that meant...can I still go completely after market with Hookers and flowmaster or dynomax or whatever or will I be effed when I have it inspected?
MM2Robinson
Oct 1, 2017 09:16 AM
tyeo098
Nov 30, 2015 06:27 PM
Camaroguy2
Sep 22, 2015 08:22 AM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
