A.I.R delete in tbi help!
Old Aug 30, 2009 | 05:06 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am wanting to buy some hooker 2055 but he has delete the A.I.R pipe and i was wondering if that would mess up my engine if i install them or are the hose that are attached to headers do nothing. Or would i have to buy some other things if i want to delete that.
Old Sep 1, 2009 | 01:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: A.I.R delete in tbi help!
Well because you're in California you'll fail the visual part of the smog test.
Otherwise, read the sticky at the top that says "Can I remove my AIR from my engine?"
The computer does not monitor the AIR system so it doesnt care.
Old Sep 1, 2009 | 07:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I know someone who will not check on the visual for smog check i will just buy them
Old Sep 1, 2009 | 11:16 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So the check engine would go on if i delete that and have to remove other stuff too just want to know that
Old Sep 3, 2009 | 11:28 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
You will be just fine.
I deleted mine with the stock manifolds; plugged the holes, yanked the pipes and the pump. Its all good.
Old Sep 4, 2009 | 12:27 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Would i need some kind of kit or things i need to buy
Old Sep 4, 2009 | 01:48 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have the hooker headers with no smog stuff and I never got a check engine light. Like Kevin said, it wont pass emissions at all, both visually and the sniffer...
Old Sep 4, 2009 | 04:29 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So it would be best to just buy some with the air tubes then
Old Sep 4, 2009 | 04:43 PM
HCR13's Avatar
Car: 1987 Trans Am
since you live in SmogNazi California...yes
Old Sep 4, 2009 | 05:14 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh pk thank you for your help
Glowsock
Sep 11, 2015 11:09 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
mantaguy
Sep 2, 2015 10:42 PM
