Header question
Old Feb 5, 2010 | 01:17 AM
RaMRoD's Avatar
Car: 1991 B4C Camaro
Engine: 355 TPI/L98 .30 Over
Transmission: Built 700R4
Axle/Gears: 3.23 Limited Slip
Header question
Hey guys, ive been a member on here for awhile, but i got a thirdgen in sept, 91 b4c, 355, shift kit, etc... my question is i wanted to know if i would have room to put these on
http://www.summitracing.com/parts/HED-68460/
I wasnt sure if long tubes will fit, without modification. Any help would be awesome.. thanks
Old Feb 5, 2010 | 04:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Header question
I had to slightly dent a primary on both sides to clear the starter (aftermarket) and k-member (aftermarket).
Getting around a 700r4 trans is tricky but doable.
https://www.thirdgen.org/forums/exha...ve-3-true.html
Old Feb 5, 2010 | 11:52 AM
RaMRoD's Avatar
Re: Header question
so its not to bad? or is it a pain in the as* and should i go with shorties?
Old Feb 5, 2010 | 07:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Header question
Depends on if you're going for duals or a single pipe.
Duals are much more difficult.
Shorties are the easiest but it depends on what you're looking for torque vs. power-wise.
Old Feb 6, 2010 | 02:19 AM
RaMRoD's Avatar
Re: Header question
well im just looking for a good sound, and long tubes jus seem like the way to go. I just wanted to get ideas on how bad it would be to do. and if i should just go with shorties, and if so what kind?
Old Feb 11, 2010 | 12:12 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Header question
Unless you need the specific performance characteristics of long tubes,
shorties are a good overall compremise for general street use:
-- improved performance,
-- easier installation
-- no clearance problems (grinding the bottom off, over bumps/dips)
As a newbie with 3 posts, Welcome.
Be sure to check out the stickies at the top of this section,
there's a wealth of info there.
Old Feb 16, 2010 | 09:15 AM
RaMRoD's Avatar
Re: Header question
What shorty header would you suggest that i get? And will it basically be just a bolt right up kinda thing?
Old Feb 16, 2010 | 12:20 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Header question
there is a guy on the boards named dyno don. He makes a 1 3/4 shorty header that I think is better than anything else out there. There will be a small difference in power as compared to long tubes. But for the ease of installation and ground clearance shorties are the way to go. i have a set of his shorties and my motor made 496 ft tq and 476 hp at the motor
Old Feb 16, 2010 | 01:18 PM
RaMRoD's Avatar
Re: Header question
Are his headers like direct bolt on? and how much do they run?
Old Feb 16, 2010 | 07:03 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Header question
you can pm him about the price, but they fit perfectly. A bunch of people on this board have them and would say the same thing
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
