Dougs Full Length Headers w BMR K member
Old Apr 3, 2010 | 07:24 PM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
I have a set of dougs full length headers on the car now with the stock k member. I had to dimple (pretty bad) the passenger side header to get it to fit around where the lower a arm bolts to the k member. Was just wondering if the BMR k member will give me more room.
Old Apr 3, 2010 | 07:32 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Dougs Full Length Headers w BMR K member
wow
Old Apr 3, 2010 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
holy crap, they are pretty much trash now.
maybe should have asked about the k-member before the hammer?
Old Apr 3, 2010 | 07:44 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Nice paper weight!
Old Apr 3, 2010 | 07:46 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
wow, u really thrashed those headers, my dougs longtubes on my stock k member fit fine, although the engine is out of the car right now so i cant show any pics, but u must have a tweaked frame or something.plus that last tube is a slip tube, you should of not welded it. you see the cut on the flange you are suppose to cut all the way through, i know they dont cut them all the way when u buy them. you really should buy a new set of headers, cause you just wasted them.
Old Apr 3, 2010 | 10:58 PM
84 Kamp311's Avatar
Engine: 406
So whats the answer to my question, my headers are fine I have a welder. Thanks for the feedback. Slip tube or no tube they still didnt fit. My 84 must be different from the newer ones, I drove my friends yea they just felt different.
Old Apr 3, 2010 | 11:04 PM
84 Kamp311's Avatar
Engine: 406
Maybe my Brodix aluminum race rite heads are making them not fit. What kind of starter are you using with dougs full length.
Old Apr 4, 2010 | 03:28 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
well, the dougs identical to hooker 2210 except they have thicker flanges. i know those dougs will fit in any year 82-92 camaro or firebird. i pretty sure there is someone on this site that has those heads and those headers. you really should take advantage of the slip tube, cause if you do u can install those headers with only three tube then install the 4th tube. you wont be able to install those headers unless u crush the tube like you did without removing the slip tube.
Old Apr 4, 2010 | 09:27 AM
84 Kamp311's Avatar
Engine: 406
So how much more you do you get with the k member.
Old Apr 4, 2010 | 09:55 AM
FueledSoul's Avatar
You can always modify the stock k-member
i had to cut and modify about 5 to 7 peaces on
the k-member and a-arm ears to keep my header primaries from looking like yours hahaha.
Ducati900ss
Sep 2, 2015 09:05 AM
lt1z350
Aug 28, 2015 05:57 AM
Wesly_66
Aug 26, 2015 09:55 PM
overdriv
Aug 20, 2015 03:52 PM
