hedman headers 68460
Old Jul 6, 2010 | 08:00 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
ok got pair hedman headers from a friend brand new for $120 but shuld i run a y pipe or true duals a local muffler shop said they wont run true duals on my car but its still a option. if i do y pipe tho what y pipe can i buy that i can fab up to work with them cause i know there is not a y piep that will fit them
Old Jul 10, 2010 | 08:58 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: hedman headers 68460
I would just go with a simple true dual exhaust system. If you want to do a Y pipe and your doing it yourself. All you need to do is pick a good spot to cross over to other pipe at a spot that will not get in the way of any maintanane that you might have to perform down the road. cut a whole in the side of the ppipe and weld the Y pipe into it. Its strait forward but i would rather run duals.
Old Apr 5, 2011 | 10:05 PM
DoWork2day's Avatar
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
I'm using 68460 on the V6/350 swap on this 1990 RS. I plan to try to run a couple of cherry bomb type mufflers, because they are smaller. Hope it don't sound like crap!
Old Apr 5, 2011 | 10:49 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
im not an expert ive only read this in several threads but arent there major ground clearance issues with thrue dual on our gen camaro?im looking into a y pipe set up for mine but i also dont race mine i just wanna get rid of factory restrictive manifolds
Old Apr 6, 2011 | 09:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are ground clearance issues with long tubes, not necessarily with dual exhaust.
Old Apr 7, 2011 | 06:03 PM
89F Body's Avatar
Car: 89 z
Engine: 96 350 HSR vortec
Transmission: 700R4 24-2800 BDR stall
Axle/Gears: 9 bolt disc posi w/3.45
Im gonna be using these headers pretty soon and the Y pipe i decided to go with was the stainless works 93-97 camaro 3" Y pipe.Im gonna need to use a new tranny cross member but it should work with minor mods to the pipes and sutch.
Old Apr 7, 2011 | 09:31 PM
DoWork2day's Avatar
You could have dual exhaust mounted to the 68470 exhaust. Even though they also sell a y pipe for 68470, you don't have to. The will basically be a shorty header.
As for me, I ended up finding an 89 Iroc the other day! 406 Chevy small block, headers, posi, built 700R4, the motor has Victor Jr intake, Dart 2.02 heads, it's the fastest car I've ever had, my other Camaro only ran 14.3 in the quarter. Anyways, my Iroc has a 3inch y pipe connected to the headers, right now it's leaking at the collector/ypipe. I'll fix it soon and post a video. Love this car, paid less than 2 grand do you believe that!
Old Apr 7, 2011 | 09:48 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
i have hedman longtubes on my car. and i currently run a true dual set up on mine. i have it installed with two Bullet type mufflers from SLP. i have great ground clearance with the SLP loudmouths compared to a regular style muffler. a lot more ground clearance!!!! have scraped yet since i put them on my car over a year ago. I think maybe a very light kiss but thats about it.
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
