Header & Ypipe Q
Old Dec 21, 2010 | 09:36 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Header & Ypipe Q
I have an 1989 305 TBI 700R4. I went snooping into advance and asked what they had available for headers and y pipe; they said only flow-tech, last i knew ricers love these headers... dont know how well it would be safe to buy these for the camaro..
I'm looking to get new headers and ypipe for my car. My cast iron anchors are cracked and starting to leak and i need to replace them soon.. just dont have money to waste on a very nice system. Looking for cheap headers and ypipe , 1 5/8th to 3" with a hi-flow cat and a single slp shotgun muffler then snake around and dual exhaust out with a "y". Thats my idea; just need some cheap headers and ypipe to get.. but dont know what would be a great fit and work?
Old Dec 21, 2010 | 10:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Header & Ypipe Q
Flowtechs are cheap, but there's better available.
Old Dec 22, 2010 | 06:37 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
ok; but explain. What do you mean theres "Better" what would make others better vs these. Bad angles; hard turns, cheap materials, etc. Rather know what im dealing with... I dont have 1k to spend on an exhaust setup, let alone $500 thats much... :\ but this rattling and leaking badly..
Old Dec 22, 2010 | 09:31 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
he means flow-techs are cheap. around $500 or less for hooker 2055's and they come with a matching y pipe. you just need to buy better gaskets then the ones they come with. like percy's. any ?'s about the 2055's just read the sticky at the top. i posted a LOT of install and part #'s stuff when i put mine in almost 2 years ago now. the fitment is great. they are for tpi not tbi but it's all only about the smog adapters i believe. i got rid of the smog stuff and just capped the a.i.r. tubes. good luck.
Old Dec 23, 2010 | 04:39 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Is there a set without air tubes? so they would be cheaper? Would you give me the part numbers; because I'd do that then if they are cheaper and come without the air tubes; because im removing mine soon.
Old Dec 23, 2010 | 06:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
2055s only come with air tubes. 2460s don't, but they're more expensive heavier steel, and you have to buy the Y separately.
Old Dec 24, 2010 | 10:43 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
would it look bad if i clip the air tubes?
I just wanted some clean looking headers.. i thought the tubes would look tacky
Old Dec 24, 2010 | 04:50 PM
lots of people have clipped and tack welded the holes. i just put caps on mine. don't even notice. and yes the 2460's are cheaper ligher weight steel and that y pipe that you purchase seperately i have heard doesn't quite fit as well. they are 3 bolt flange collectors i think where as the 2055's are ball and socket. alot better fitment.
Old Dec 25, 2010 | 08:40 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I'll look into it; thanks!
Old Jan 1, 2011 | 09:27 PM
travis_henry's Avatar
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
hedman makes a pretty decent header with a Y pipe. 160 bucks or so. its nothing fancy but its what sounds like your asking for.
Old Jan 1, 2011 | 09:35 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I've got got the 2460's, then a y-pipe dumping into a 3" system --
Magnaflow Hi-Flow cat, and stainless cat-back system.
It's been quite an ordeal, which I will document here in more detail
when it's totally finished. But for the topic of where this thread is
going, let me just say that IF you go with the 2460's, spring for
the matching Hooker y-pipe, hopefully minimizing fitment issues.
Good luck.
Old Jan 2, 2011 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following is a direct-fit system: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
I too cut and welded the tubes. You can see how that turned out in the pics in post #16 of the following link:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jan 2, 2011 | 01:58 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Do you have a set for yourself? and your own personal experience?
Good luck.
I'll check them out; hopefully its not to much seperate.
JamesC
I might just got with those headers and snip the air tubes since i dont need them.
How long does that cat last for? I bought an oem for mine for STOCK and its only last a little less than 2 years and the seam is rusting.. :\
Also I'm going SLP Loudmouth Shotgun right after the cat and having someone run the pipes... or would there be a pipe kit without the muffler online some where?
thanks everyone for your input!
Old Jan 2, 2011 | 02:13 PM
JamesC's Avatar
I've been running it for several years without issue.
JamesC
Old Jan 2, 2011 | 02:24 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i bought these from ebay but the paking list is from summit : headers part number is sum-g9005 an the y pipe part number is big -11102yflt .
i haven't insalled mine yet because i'm gonna delete the smog pump an ac when i do but they cost me 241.35 including shipping . these don't have the smog pipes on them . heres a link of the ones i got : http://cgi.ebay.com/NEW-SHORTY-HEADE...item4153a3a399
Old Jan 2, 2011 | 09:56 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
Yes i have done it to the past 3 camaros i have had and my friend Ryans Iroc i have had awsome sound and great flow with this setup. its a simple setup and can be done in a few hours taking the old exhaust off and putting the new back in. Trust me you will love it!!!
Old Jan 3, 2011 | 10:51 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
JamesC
ok; thanks for your input.
have a part #?
Old Jan 10, 2011 | 09:28 PM
The link from freaky looks like a pretty good deal. I wonder how the
e-bay seller is interacts w/ Summit? At any rate, after my experience,
I will definitely recommend a matched set of components like that.
Freaky, when you do the AC delete, I need some of the wiring harness.
If you're interested in some financial help defraying the header cost,
PM me.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
