Smog Removal
Old Jan 17, 2011 | 03:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Smog Removal
I've searched quite a few times on this and wanting to finalize what I understand.
My question is what exactly needs to be removed? And would someone supply pictures of each things or highlight what I need to remove. I own a 1989 Camaro 305TBI.
My buddy told me its also routed to the coolant valve that controls the heater which allows coolant to the core (which i dont believe).
What I understand.
Belt Needed: Dayco #935K6 which is a 6 rib 96.8" belt
There was also another belt supplied P/N: 10186167 (which i have no clue if it relates to the dayco?..
Old Jan 18, 2011 | 07:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Smog Removal
there should be some pretty detailed info on this swap here:
https://www.thirdgen.org/serpentine
the belt number you gave is not going to be correct - 935k6 is a 93.5" 6-rib belt (only good if you have an underdrive crank pulley) you need a 968k6 (or 5060968 if you want dayco, the other number's dayco's economy driverite belt)
you are not adding any additional components (coolant valve), just rerouting the belt around the components you currently have.
Old Jan 18, 2011 | 09:16 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Smog Removal
https://www.thirdgen.org/forums/faq-...injection.html
thier is a thread basically show the exhaust manifold and the air tubes. manifold dont need to be removed but it shows the hoses going across
https://www.thirdgen.org/forums/faq-...lete-smog.html
thier is the thread about the smog pump itself and if you dont want to change the belt. I changed the belt. no problems.
Old Jan 18, 2011 | 11:30 AM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Re: Smog Removal
Simple- remove the smog pump which will get rid of alot tubes and stuff. You also need to get rid of the egr valve that is near the y-pipe as it won't allow exhaust flow if left in. Then take the belts and run them. Youl have to cut one of the belts to fit since you got rid of the smog pump. Bring the belt to auto zone and theyll find a size that fits. Thats what I did.
Old Jan 18, 2011 | 12:38 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Smog Removal
Last I checked the EGR valve was mounted to the intake manifold.
Old Jan 18, 2011 | 02:30 PM
MikeSammy's Avatar
Re: Smog Removal
your probably right, but there was some kind of emission thing on the y-pipe that closed the flow of exhaust off. I removed it on my 305 and gained quite a bit of power and the car was louder too.
Old Jan 18, 2011 | 03:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Smog Removal
What would be the correct belt if I remove the smog pump and leave it without a pulley?
Old Jan 18, 2011 | 03:55 PM
MikeSammy's Avatar
Re: Smog Removal
I had the same problem of finding belts after removing the smog pump. so, what I did is cut the belt to the lenght that I needed and brought it to auto zone and they found one simiar in size.
Old Jan 18, 2011 | 04:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Smog Removal
I too had to experiment with belt sizes - I started with the one in the tech article, but had to trade in once or twice to get the right size for me.
One other thing - part of the AIR system is a small silver tube that runs up from the cat converter - I cut mine at the cat, pinched it closed with vice grips, and welded it shut (blow torch and metal coat hanger).
Old Jan 18, 2011 | 04:46 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Smog Removal
Since you two have the "correct" belt length, do you know what the length is? kind of hard for me to cut the belt and some how get to the parts store and hope they have the right length belt...
Old Jan 18, 2011 | 06:41 PM
Car: 1992 RS
Engine: Carbed 350
Re: Smog Removal
Sorry, I don't remember. I sold that car a few years back. And my 1992 is set up with a whole different configuration.
Old Jan 18, 2011 | 10:19 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Smog Removal
If your getting rid of the smog pump and not installing the delete pulley. You will need a belt 2.6 inches longer than stock. Unless you have underdrive pulleys then you'll need a belt 1 inch shorter than stock. So basically get the belt size off the belt you have on your car and go up 2.6 inches (or as close to it as you can) a little smaller might work, and it will stretch a little. A little bigger should work too
Old Jan 19, 2011 | 07:54 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Smog Removal
Thanks, I went to autozone and they gave me the stock size which is 94.5" (http://www.autozone.com/autozone/par...ntifier=884536) so probably aim for a 96 or 97" maybe?... whats the best brand belt to get also? dont want any cheapo ones...
Old Jan 19, 2011 | 10:59 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Smog Removal
my belt preference is goodyear gatorback. I have a hard time finding them. So I either run Gates premium belts, or dayco poly cog (hard to find too) You can also find a dayco poly rib which isnt bad either. I dont run Duralast brand, or cheap lines of any belt.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
