Ebay longtubes
Old Aug 7, 2017 | 01:29 PM
  #401
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Ebay longtubes
Originally Posted by IROCZ1989
Just cut and tack weld it. Then bring it to a professional. If im unsure I just let someone who does it for a living give an honest opinion on the outcome.
That's a good idea. I have a friend that is a superb TIG welder. If the tack welds go on easy I'll try to TIG a short segment and based on that outcome, I'll know if I can do it. I think as long as the tubes mate together perfectly with no open root, I should be able to do it.
Old Aug 26, 2017 | 11:06 AM
  #402
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
I had my friend who has his own fabrication/restoration help me out. Didn't take long. Took some pictures of the space available and what needed done and then went to his place and got to work. Took two hours. Cut off the front primary tube, re-positioned and added a turn. Clears the spark plug fine! Problem is the A arm is at angle towards the nose of the car and that tube now hits the a arm so I had to cut it apart and remake it. I won't clutter this thread with lots of explanation, you can read my build thread for that. Here is the picture of what we made and another of what I had to remake. Back purging this will eat up some argon for sure...
Old Aug 28, 2017 | 07:08 AM
  #403
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Ebay longtubes
Ok, So let me see if I can get this straight. You have the pre eliminator AFR 190 heads. They where available in straight, angle or L98 Angle plug positions. So do you have the actually Angle plug heads or the L98 angle plug heads. I am assuming that there is a slight difference between the two.
I am currently running the L98 version part #1018. The regular angle plug heads where part #1000, 1001, 1005, and 1006 or 1032 for cnc package. Depending on the chamber size and having heat risers. I am really hoping I will not have this issue.
Please help clarify. Thanks
Old Aug 28, 2017 | 07:28 AM
  #404
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Ebay longtubes
AFR 190 PRE ELIMINATOR HEAD
190 Angle plug part numbers #1000, 1001, 1005, 1006 and 1032 for cnc competition
190 L98 heads part numbers # 1017, 1018 and 1088 for cnc competition
Old Aug 28, 2017 | 09:35 AM
  #405
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
I had no idea that their were two different angles available for the AFRs (pre-eliminator) so I don't know what version I have. The only thing I can say about them is I did had them flow bench'd and they flowed what the competition line was reported to flow, so they must be the comp port version. Were comp ports available in both angles? Can anyone get out a protractor and measure what an L98 angle is? In case I hadn't said it before, the Hooker long tubes had no problem with these plug angles.
Old Aug 28, 2017 | 11:23 AM
  #406
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Ebay longtubes
Yes comp ports was available in all three designs.
Angle #1032
Straight # 1085
L98 #1088
If it uses the 87-up intake then they will be the L98 version just like a stock TPI center bolt head. Luckily I found my AFR 2003 Master Catalog & technical guide. It has the parts numbers as well as flow numbers for all 2003 AFR heads.
Old Aug 28, 2017 | 01:01 PM
  #407
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
Angle #1032
Straight # 1085
L98 #1088
I currently have the 86 and older valve covers and intake manifold design, but I am fairly certain it can take either valve cover.
Old Aug 28, 2017 | 01:45 PM
  #408
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Ebay longtubes
My heads came with only the center bolt valve cover provisions. No bosses on the side for the older style covers. Hopefully the headers will work for me.
Old Aug 28, 2017 | 03:40 PM
  #409
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
PM me if they don't, perhaps I could buy them from you or "fix them" for you.
Old Aug 29, 2017 | 07:02 AM
  #410
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Ebay longtubes
Thanks, I will keep you in mind.
I am interested in how you are going to run the rest of the exhaust.
Old Aug 29, 2017 | 07:13 AM
  #411
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Ebay longtubes
Tibo, I am selling my set, they just need to be cleaned off. They sounded awesome, and flowed extremely well, I just decided to go back to the turbo setup in my case otherwise I would have kept them. Let me know if anyone is interested, rarely even used them. First vid shows how they sound, second vid shows them removed. Price I stated in the video is for everyone...
- Rob
Old Aug 29, 2017 | 12:01 PM
  #412
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
- Rob
I have a brand new set in a box too for a rainy day.
Still don't know why you went back to turbo. There was a D1SC for sale for short money for like 2 months on here, and a few HSR intakes.
-- Joe
Old Aug 29, 2017 | 12:31 PM
  #413
Re: Ebay longtubes
-- Joe
I tell ya Joe, was hearing so much about thrown belts and such, then when you stopped with your build I knew something was up. Once I realized you might have been having issues too with thrown belts, I was like... let me just throw that damn turbo on it again. Kicked my butt with it though this passed weekend, did a lot even after that video. Got a lot done, long overdue. Waiting on an On3 Turbo, but wait til you see what I did with the temporary one lol.
- Rob
Old Aug 30, 2017 | 10:35 AM
  #414
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
- Rob
Bracket flex causes belt issues. Lots of people have belt issues. Lots don't.
I don't know how many turbo cars are still on the board that are actually driven. I know there is an absurd number of supercharged cars.
Maybe everyone posts at the turboforums.
I know my experience with the turbo was heat + lag. I know a lot of guys I talk to who race turbo cars run very inconsistent. They have a lot of excuses for why the car seems to run differently. The supercharged cars all seem to run very consistent. Maybe it's just a New England thing.
-- Joe
Old Aug 30, 2017 | 11:02 PM
  #415
Re: Ebay longtubes
-- Joe
I'll agree with you there Joe, almost everyone on here builds their turbo third gens for the track, rarely see them being driven on the street. Aside from Steve, aka ZZ3astro, I haven't seen much on here either running on a consistent basis. Well, I gotta give props to Torched though, his turbo bird is very sweet on the street. Pretty fast third gen built for the street, the way I like to see them...
Old Aug 31, 2017 | 09:25 AM
  #416
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Ebay longtubes
I haven't been following his thread or youtube videos in nearly a year, but I know he was having a lot of weird problems for the longest time.
There is a few single turbo cars on here, and a few builds.
-- Joe
Old Jan 31, 2018 | 07:24 PM
  #417
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: Ebay longtubes
So fast forward to 2018, do they still have flange issues on these headers? I am looking to get better ground clearance then what I have with Hooker long tubes. I can fix them if they do was just curious if anyone has grabbed a pair recently.
Old Feb 1, 2018 | 05:19 AM
  #418
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: Ebay longtubes
If anyones interested I have a real set of Stainless Works longtubes that these are modeled after. Zero issues. Check classifieds.
Old Feb 1, 2018 | 06:07 AM
  #419
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: Ebay longtubes
I can let you know within next week or so as I have my new engine sitting on the stand and am hoping to test fit the headers over the weekend.
Old Feb 1, 2018 | 09:48 AM
  #420
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
My header's flanges had no issues. If you dimple the primary by the flange for bolt head clearance it really helps.
Old Mar 18, 2018 | 09:49 PM
  #421
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Ebay longtubes
I read the thread here and followed on Facebook. Have a 305 with a t56 and stock clutch assembly. Will these fit my application and does anyone have pics ?
I plant to get a set and post as well
Old Mar 18, 2018 | 09:58 PM
  #422
TORN's Avatar
Car: 88 IROC-Z
Re: Ebay longtubes
Short answer yes, you will need to heat and massage the 3 inch area to get clearance. I can take pics tomorrow. Didn't matter to me as I cut off the 3 into 2.5 and added 3 inch Stainless steel to attach to the Hooker blackheart dual exhaust.
Also Flanges fit the heads perfect. They got the hole issues fixed.
Old Mar 18, 2018 | 11:11 PM
  #423
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
You sure you read the entire thread? Post #304 picture #2 shows that you just need to grind the ridge off the side of the slave cylinder housing and you're good to go. It's exactly what I did. You could dent the effected area of the header as an alternative but I wouldn't fool around with heating these up with a rosebud in order to move them. They fit pretty tight so you would need to heat them up on the car which is really begging for trouble.
Old Mar 18, 2018 | 11:32 PM
  #424
tonys91rs's Avatar
Car: 91 Camaro RS
Re: Ebay longtubes
I may have misunderstood that. But thanks for pointing it out. That does help
Old Mar 18, 2018 | 11:33 PM
  #425
tonys91rs's Avatar
Car: 91 Camaro RS
Re: Ebay longtubes
I have a bmr Crossmember. Will it pass under without bei g too low or should I get a hawks Crossmember? I already have a 2inch drop on the car ?
Old Mar 22, 2018 | 10:08 AM
  #426
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Ebay longtubes
I bought the HAWKS xmem and wasn't too happy with it. The fitment between the rails was tight and sort of affected the alignment of the mount holes.
I'm planning on modding my Spohn xmem as it fits excellent.
Old Mar 22, 2018 | 10:23 AM
  #427
Ed1LE's Avatar
Engine: 5.7, 5.0
Re: Ebay longtubes
I'm currently running a Spohn and was thinking of switching to the Hawks but have read mixed reviews regarding figment. The Spohn is a bulky piece though and hangs low. How do you plan to modify?
Old Mar 22, 2018 | 08:03 PM
  #428
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Ebay longtubes
On the pas side of the xmem im going to run a piece of channel or rounded rectangle from just off center up to the plate on that side then cut the old parts out so when that side is done its cleared for the exhaust to run thru and no geometry will be affected.
as for the dr side im not sure as that side dosent have the side plate like the pas side. i did trim the piece that hangs down under the cross bar so its even with the underside.
Old May 28, 2018 | 05:59 PM
  #429
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Ebay longtubes
Man... These things are back down to $180 shipped.
https://www.ebay.com/itm/82-92-CAMAR...item2f1a3da6eb
Old May 28, 2018 | 08:16 PM
  #430
soupman's Avatar
Re: Ebay longtubes
I have a new set in the box still never opened. Will sell them for $140 plus shipping if anyone wants them.
Old May 28, 2018 | 09:12 PM
  #431
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Re: Ebay longtubes
Where are you at? I'm interested, how much would shipping be to Austin, TX 78744
Old May 28, 2018 | 09:19 PM
  #432
soupman's Avatar
Re: Ebay longtubes
Syracuse NY. Will get you a price.
Old Jul 27, 2018 | 10:11 PM
  #433
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: Ebay longtubes
bringing this back up
​​​​​​​anyone with these have any issues with ground clearance?
Old Jul 27, 2018 | 11:02 PM
  #434
Re: Ebay longtubes
None whatsoever...
Old Jul 27, 2018 | 11:19 PM
  #435
Stuman's Avatar
Car: 1989 Z28 Camaro
Engine: removed 406 building 383
Transmission: 700R4 swapping to T56
Axle/Gears: Ford 9" 3.70 going to 4.10 or 4.30
Re: Ebay longtubes
My OBX stainless long tubes came today just before I had to go to work. They look nice and are just as shown in the pictures. I snapped a quick picture when I took them out of the box. I will unpack all the pieces when I get home in the morning and get some better pictures. I plan to mock up my engine with my AFR 210 heads and bellhousing with slave cylinder to check as many clearances as I can before going into the car with them.
Old Jul 28, 2018 | 01:05 AM
  #436
zman1969's Avatar
Car: 90 Formula 350
Re: Ebay longtubes
i was meaning the headers
Old Jul 28, 2018 | 01:15 AM
  #437
Re: Ebay longtubes
Only complaint is the drivers side hits a little by the collector, and the passenger side hits the trans mount. Drove it maybe a few days like that when I couldn't take it anymore, and started cutting to make some room. Perfectly fine after that. Haven't bottomed out yet, and I drive it hard. So to answer your question, plenti-o-room...
- Rob
Old Jul 28, 2018 | 10:04 AM
  #438
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
These headers have better ground clearance than the Hooker long tubes, very unlikely to have ground clearance issue with these headers.
Old Aug 11, 2018 | 09:13 AM
  #439
zman1969's Avatar
Car: 90 Formula 350
Re: Ebay longtubes
thank you that was my concern the ground clearance. I had a set of speed engineering on my 69 that hung way too low
Old Aug 19, 2018 | 09:58 AM
  #440
Stuman's Avatar
Re: Ebay longtubes
Hi Tibo, the picture you referenced as in Post #304 picture #2, where can I find that? I ordered my Quick Time bellhousing for my LT1 T56 swap and was going to mock up the block, heads, bellhousing and stainless long tubes in the shop and try to resolve the slave mounting clearance issue and I bought some ACCEL shorty plugs for my AFR 210 heads to see if those will help the plug clearance problem. Any pictures of these issues would be helpful as my bellhousing will be here Tuesday and I will start on checkout.
Old Aug 19, 2018 | 11:07 AM
  #441
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
I'm not sure what you're looking to find. That is the stock bellhousing that he and I both ground down slightly to remove the ridge. Or is it that you are having trouble with the spark plugs and the headers on your accel headers?
Old Aug 19, 2018 | 12:18 PM
  #442
Stuman's Avatar
Re: Ebay longtubes
Hi, I have heard of both clearance problems, the plugs and the bellhousing where the slave mounts. I'm trying to eliminate the problems that I can before installing in the car..
Old Aug 19, 2018 | 02:34 PM
  #443
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
From what I read and discovered, if you have older AFR heads the spark plugs will be an issue and Accel shorties will not work. I've never seen aftermarket bellhousings in person with a T56 so I don't know if they would pose a problem either.
Old Aug 19, 2018 | 06:59 PM
  #444
Stuman's Avatar
Re: Ebay longtubes
My heads were purchased about May of 2018.from AFR. I figure I could look at these clearance issues and try to resolve them before installing. When I get time off from worlk and mock this up with the Quick Time bellhousing and I will take pictures and post them and maybe it will help someone else trying to do this.
Old Aug 19, 2018 | 09:17 PM
  #445
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
Your heads are brand spanking new. Anesthisis and some others had said and shown that the newer version that you have posses no problems with spark plugs.
Old Feb 14, 2019 | 11:39 AM
  #446
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Ebay longtubes
So I assume that all of these cheap SS longtubes on ebay are really the same and just a different seller?
Need a set for my new dirt car and figured the price is right for the application. Plus would give me a feel for if I want them on my street Camaro or not.
Old Feb 14, 2019 | 10:14 PM
  #447
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Ebay longtubes
Seems that way. Most likely an oversees company made a few hundred sets and sent them over and some American internet vendors bought them and are selling the same ones. Speed engineering probably makes their own or perhaps theirs were made by these other companies that turned around and stole the design.
Old Feb 15, 2019 | 04:28 AM
  #448
IROCZ1989's Avatar
Car: 1989 IrocZ
Re: Ebay longtubes
They are SW copies with subpar materials & welds. The welds on the primaries are night and day. Sw comes with a solid mounting flange as well. I'll post up the welds later on.Call SW and ask them about the Ebay thirdgen set. I talked to them after I had a my set about a year from Hawks. They are very aware of these and have a low opinion on them.
Old Feb 15, 2019 | 07:26 AM
  #449
Re: Ebay longtubes
I have another used set like these that I am selling for half the price of the ebay auctions. I tossed the header bolts though because they bottomed out, as well as hit the primaries when going in, so you would have to get another set unless I come across them in my garage. I wouldn't recommend those bolts anyway. If you're local, come on over and check them out, I don't mind. If you're in Brooklyn/Queens or Long Island, could more than likely meet up with you. If you're further, shipping these suckers is on you...
- Rob
Old Feb 15, 2019 | 09:44 AM
  #450
Drew's Avatar
Re: Ebay longtubes
You don't say...
