86 Iroc z28 355
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
86 Iroc z28 355
I got a 86 Iroc Z28, with a 355ci making roughly 310hp (carb'd) and a 700r4. Want to put true duals with headers, any recommended kits? Looking at hooker 2460 headers, but have no idea what to do as far as the rest. Have no lift to custom make it, AIR system is gone. Any help?
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: 86 Iroc z28 355
there are no kits for true duals on thirdgens its all custom jobs
Car: 87 Iroc
Engine: 350tpi
Re: 86 Iroc z28 355
ended up getting the summit 99.99 cheapos. I highly recommend painting them again with high temp paint, before installing. fitment isnt too bad. but **** is close.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 86 Iroc z28 355
For the record the Hedmans are a great header and a great value. You need to trim a non-important part of the a-arm perch off and dent one of the primaries around the steering box and thats about it.
Re: 86 Iroc z28 355
i ran the hedman longtubes on both my 86 and 82 trans ams and never had to trim anything i konw some do but idk why i idnt have to. also installed a set of hedman shortys and their y pipe on a friends car and was impressed with them for the price.
Car: 87 Iroc
Engine: 350tpi
Re: 86 Iroc z28 355
yeah definetly going to repaint them this winter, all the **** it came with is just bout gone now.
Car: 1992 Camaro RS
Re: 86 Iroc z28 355
If you want to paint them, makes ure you use some high temp header paint.
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
