is 2.5in. enough?
Old May 22, 2011 | 11:40 AM
305lg4z28's Avatar
Car: 1985 z28
Engine: 305 lg4
is 2.5in. enough?
im considering a dynomax system for my 85 z28. its a 2.5in. system but everyone seems to say you need 3in. im just wondering what anyone thinks..
Old May 22, 2011 | 11:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: is 2.5in. enough?
if its a stockish engine, it will be fine. if its a 305lg4 like your name implies, you will be fine.
Old May 22, 2011 | 12:10 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup. but if you plan to do a ton of upgrades then you might want to go 3 inch now instead of spending money to only spend more later...just a thought.
Old May 22, 2011 | 05:16 PM
torque_is_good's Avatar
right now dynomax has a $75 rebate. You can in essence get a complete system shipped to you door for anywhere from $120-$140 post rebate. You have nothing to lose at those prices
If you know anyone who has a stock system you shoudl tell them about this deal. heck, if it rusts in 3-4 years who cares?
Old May 22, 2011 | 07:15 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
This is true. Normally I do not recommend the Dynomax setup (but the tailpipes are useful for a stock look), but for that price it's not a bad idea for a stock motor. However, since the intermediate pipe is a single piece, you need a lift to install it.
Old May 23, 2011 | 01:28 PM
85KSz28's Avatar
Car: 85 Pontiac Trans Am
Engine: 400 SBC
I've read where you need a lift before but I just did my 87 on ramps/jack stands. I was replacing the panhard bar at the same time and did have to remove the brace as well (as I remember) to get it in, but once those things are out of the way it slips right in. I did have the jack stands positioned so that the rear was hanging down as well. With just a couple bolts removed it's a piece of cake. And you can't beat that rebate.
Old May 23, 2011 | 10:14 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I like dynomax. But is it an ultraflo kit or super turbo kit?
Old May 25, 2011 | 03:42 PM
305lg4z28's Avatar
Car: 1985 z28
Engine: 305 lg4
its a super turbo it
Old May 30, 2011 | 11:33 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
No it is not large enough for a 305ci V8 engine...
Old May 30, 2011 | 11:47 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Not to threadjack, but I just found a 2.5" exhaust behind my 305 TPI. I never bothered to check before because I assumed the exhaust suited the headers. But the Y pipe is 2.5" inside diameter, and the cat back is 2.5" outside. Am I getting choked?
Old May 30, 2011 | 12:45 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
It should be sufficient. optimal probably not. but sufficient.
G92Bill
Nov 14, 2012 10:09 PM
LostX
Mar 21, 2012 07:05 AM
komponoser
Dec 30, 2009 12:46 PM
Mr.K
Apr 28, 2009 03:43 PM
