Headers for RHD conversions
Old Feb 15, 2016 | 01:32 PM
  #201
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Re: Headers for RHD conversions
I'll give it a try this afternoon and see. Hopefully this should be the last hurdle before starting the car.
Old Apr 20, 2016 | 10:07 PM
  #202
Aussi IROC's Avatar
Car: 1989 IROC 5.7 TPI
As a side issue, I am trying to remove the RHS manifold. All the bolts are undone and it moves up and down but wont go sideways as it appears to be hitting "something". The steering column is close but not hitting it. Can't get it to move out 1mm. any ideas?
Old Apr 20, 2016 | 10:09 PM
  #203
evilstuie's Avatar
Have you unbolted it from the bottom of the exhaust as well?
Old Apr 20, 2016 | 10:10 PM
  #204
evilstuie's Avatar
It could just be gasket crap holding it on, maybe try gently tapping a flat tip screw driver to pry it off?
Old Apr 21, 2016 | 01:08 AM
  #205
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
How did you end up going Stuie, did you get yours sorted in the end ?
Old Apr 22, 2016 | 05:00 AM
  #206
evilstuie's Avatar
Oh the journey I've been through....
But yess all finally sorted.
My last hurdle is getting the 3 bolts on the header flange tightened at the same time as bolting the extractors to the heads at the same time as slipping the steering shaft on, at the same time as putting the spark plugs in, but it all fits without hitting anything.
I even managed to get the truck serpentine brackets modified enough to work and clear
Now onto starter wiring, fuel pump wiring, PCM power wiring, gauge wiring, PCM flashing, then maybe car starting
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
redformula88
Oct 14, 2015 06:08 PM
LittleFranks
Oct 7, 2015 11:26 PM
Chad Speier
Sep 24, 2015 12:32 PM
