X-Pipe comparison
Old Sep 18, 2012 | 10:13 PM
mtac454's Avatar
X-Pipe comparison
Has anybody ever compared X-pipes according to the shape because, if it alters the flow, won't it alter performance?Here are a couple diff shape I have seen, I would like to know which one is best before I buy one.
Old Sep 18, 2012 | 10:24 PM
mtac454's Avatar
Re: X-Pipe comparison
and these
Attached Thumbnails X-Pipe comparison-xpipe2.jpg   X-Pipe comparison-xpipe4.jpg
Old Sep 23, 2012 | 09:47 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
basically, air doesnt like corners. you want the turns as gentle as possible. this goes for x-pipes as well.
Old Sep 27, 2012 | 11:40 PM
mtac454's Avatar
That is what I was thinking.
Old Sep 28, 2012 | 07:00 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
this is a sample of what the NASCAR boys run... they put a lot of thought into this stuff and use what works..
Old Sep 28, 2012 | 07:37 AM
Twin_Turbo's Avatar
the nascar pipes are made so that the 2 sides are open to each other but the indicidual diameters are hardly reduced, unlike most of what you see for sale.
Here's what I built for a corvette, same principle.
Old Sep 28, 2012 | 09:38 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Dont like the 3rd one looks like youre losing area.
Put on what fits and you can afford you will never see a difference in power with any of them, or without one altogether.
I only put one on mine to kill off any high pitched exhaust noise which it does
Other than that I dont like them, one more thing to get in the way when dropping the Dshaft or trans.
Any more thought than $ or looks is a waste of your time.
Old Sep 28, 2012 | 10:57 PM
novaderrik's Avatar
Car: 86 Camaro
an X pipe will usually show an increase in power across the rpm band, and are easily removed for trans access by simply using a couple of band clamps after the X to hold things together.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Camaro_383
Sep 11, 2015 11:28 PM
