WBO2 Placement
Old Feb 14, 2013 | 02:37 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
WBO2 Placement
On a dual cat shorty header system, where is the best place to put the WBO2? I would think that at the y where both banks merge, but can widebands be placed post cat?
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: WBO2 Placement
Before the cat, if it's to do any good.
Old Feb 14, 2013 | 02:56 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: WBO2 Placement
Thats what I figured, but wanted to confirm. Thanks
Old Feb 18, 2013 | 04:01 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: WBO2 Placement
I have mine on the y where both banks of cylinders merge. Its a heated sensor so it should be fine that far away from the engine. You want it before cat.
Old Feb 19, 2013 | 08:20 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: WBO2 Placement
At the y pipe would be ideal so that I can pick up both banks. But with a dual cat option, the y is after the cats.
Here is another question. Should the NB and WB be on the same bank? If they are not, will I be fighting with one or the other?
Old Feb 19, 2013 | 08:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: WBO2 Placement
I dont think it matters if both are on same bank as long as they are positioned right. I would stick wideband in one bank before cats. Real nice if you can get 2 bungs, one for each side and move it over to check other bank but both should be close. Unless you have serious issues with inj firing and air distribution, but you wont need a wideband to notice that
Old Feb 19, 2013 | 09:07 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: WBO2 Placement
That is actually what I am going to do. I am going to be welding two bungs on on each bank and go between them when I tune to make sure that nothing weird is happening. I asked the question as I don't want to be tuning a lean area when the NB is reporting rich.
Old Feb 19, 2013 | 09:48 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: WBO2 Placement
Placing the WBO2 in one bank or the other is fine. Both banks will be close on fueling, unless there are mechanical issues, which as already said, you'd notice without the WBO2 sensor.
Ikes 91Z
Dec 9, 2015 03:49 PM
ken3983
Aug 23, 2015 07:31 PM
MonteCarSlow
Jul 9, 2003 07:38 AM
MR. KIDD
Feb 23, 2003 09:09 AM
'89 IROC Vert
Feb 8, 2003 01:24 PM
