Magnaflow 16450 y pipe questions
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
Hey all the Y pipe on my 87 L98 has finally given up, I was going to use the walker direct fit y pipe when someone recommended the magnaflow 16450. http://www.summitracing.com/parts/mpe-16450
Are there any fitment issues with this y pipe?
Can the starter still be changed with this y pipe? The stock starter and y pipe on the 5.7 is a puzzle but it can be done.
I am using the stock manifolds currently, the rust on the bolts is keeping me from going to headers...
Re: Magnaflow 16450 y pipe questions
I have this pipe on my car and had no fitment issues. The starter can be removed as usual. The only fitment issue I had, and it is minor is that the pipe was touching the plastic wheel well dust shield and I had to trim it back a bit so it would not melt. But it is a very nice piece.
thanks, I'm going to order this one. Just had too many times where the exact fit required all sorts of modifications...
Car: Iroc z 1990
Engine: 5.7 tpi flat top pistons
Transmission: 5 speed
your link to Summit says there is no bung for the O2 sensor, is that because your O2 is mounted into the cast iron manifold?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I sell that y-pipe, and even have one on my GTA - quality SS construction, great fit, and a great transition of pipes into the cat (unlike the factory).
Can't go wrong.
Car: Iroc z 1990
My car is 1990 iroc, original 5.0 block replaced 4 bolt 5.7, I was thinking of using the 16450 y pipe, when I look at applications, on Summits site, it states 88-89, I was under the impression that the 90 was identical, the Walker also says 88-89, I would like to go magnaflow front to back with the mpe 36019 california 3000 Cat, and 16829 cat back exhaust. Are there any issues with the Y pipe or using the single 3" Cat ( ground clearance ) vs. the original 2 cat configuration which seemed prone to finding speed bumps itself. Just found 3rd gen site and it is a very welcome resource.
One of the pipes will be like 2 inches short of the manifold on the passenger side for some reason on the 1990 if you use this setup. I saw a few complaints online...
what size pipe is this magnaflow?
Engine: 4++,350 & 305 CIs
I thought the pass side was different on the lower performance models?
Car: Iroc z 1990
re shortness of pipe, pulled out the old parts book, for 1990 at least, all 5.7 and the 5.0F equipped with mk6 manual trans the manifold p/n's are (LH) 14094063, (RH) 14094064, where as the 5.0F with m39 or autos have a different (RH) 10128448 manifold that is shared with the 5.0E, the E uses a different (LH) 10046123 exclusive to that model. possible that the cars with problems are 5.0 auto, M39 manual, or E model, is it the passenger side that is the problem?
