header gaskets
Old Mar 23, 2014 | 05:15 PM
racerx520's Avatar
header gaskets
need suggestions on which header gaskets to get. when taking my headers off of my 305, i noticed the header gaskets were basically all blown out (multi layered aluminum gaskets). a friend of mine suggested solid copper gaskets but i was told by the performance shop that the aluminum gaskets were the strongest and longest lasting. i only have had the headers on for like 6-7 years, 2 of which it has been resting in the garage minus the maybe 40 days per year its nice enough to take the car out.
Old Mar 23, 2014 | 05:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: header gaskets
Fel-pro 1404 (or 1405)
1" long (small head) header bolts and a dab of anti-seize on the threads.
Old Mar 23, 2014 | 06:20 PM
racerx520's Avatar
Re: header gaskets
both are listed as steel core gaskets. are those good? also one is for vortec heads, not sure if thats quite what i need. and i have small head (7/16") header bolts, but you put anti-seize on them? i just noticed mine had started backing out, one was only being held in by the gasket, and 2 or 3 others were only hand tight anymore. if anything i was thinking of loctiting them
Old Mar 23, 2014 | 08:01 PM
Joe Tag's Avatar
Re: header gaskets
Go with copper. It has a melting point of 2,000, aluminum is around 1,200. If you ever pull the headers, you can just anneal them with a torch and reuse them.
Old Mar 23, 2014 | 08:14 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: header gaskets
I have always had good luck with MR. GASKET copper ones . well worth the price . good luck .
Old Mar 23, 2014 | 08:33 PM
TTOP350's Avatar
Re: header gaskets
The reason the bolts back out is because they are 2 short, not enuff threads grabing in the heads. And yes, I do put a lil dab of anti-seize on them.
I have used those fel-pro gaskets on many builds over the last 20 plus years, I have even reused the gaskets a few times. I put a lil dab of anti-seize on both sides of the gaskets around the ports, helps keep them from sticking so you can reuse them.
Old Mar 23, 2014 | 09:18 PM
racerx520's Avatar
Re: header gaskets
thanks for the input everyone. i think i will wind up going with copper gaskets. my bolts are about 1" already. they just seem to back out on their own. would loctite just burn up?
Old Mar 23, 2014 | 09:34 PM
Joe Tag's Avatar
Re: header gaskets
That's just the nature of the beast. I would not use locktite. Look into locking header bolts. You can go cheap with spectre, around $20, or there are more expensive systems. Frankly, I'm surprised you went as long as you did without leaks.
Old Mar 23, 2014 | 10:50 PM
UNCLE TOM's Avatar
Re: header gaskets
there are many thoughts on header gaskets . the ones that I feel all will agree are preparation & torque . all surfaces clean , flat and smooth . torque from the center outward . re-torque same sequence . TORQUE CENTER OUTWARD , (5) 0 (3) (1) 00 (2) (4) 0 (6) ck. & re-torque several times . good luck .
Old Mar 24, 2014 | 07:50 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: header gaskets
I have had good luck with FEL-PRO MS9275
Old Mar 24, 2014 | 10:32 AM
racerx520's Avatar
Re: header gaskets
judging by the header gasket burnout, they must have been leaking, just not bad enough for me to hear it very well i guess. I'll try the copper gaskets, and i'll try the torquing them in place in the correct order that you listed. as for the anti-seize, i just cant see how that would help keep these from backing out.
Old Mar 24, 2014 | 10:33 AM
midias's Avatar
Re: header gaskets
Friction does not stop them from backing out, tension does. Get some 1" screws and tr torque them after your first engine hot / cold cycle.
Old Mar 24, 2014 | 10:50 AM
midias's Avatar
Re: header gaskets
I believe these are the way to go
ARP Chromoly Header Bolt Kits 100-1110
Old Mar 24, 2014 | 12:15 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: header gaskets
i like what uncle Tom said about nice clean surfaces. i've seen many new headers come with small pieces of welding splatter on the sealing surfaces. its always a good idea to run a file over them.
in my experience it doesnt matter how much you tighten the bolts, after the motor goes through a few heat cycles its gonna loosen up and you'll have to re-tighten the bolts. its just the nature of the beast.
Old Mar 24, 2014 | 05:24 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: header gaskets
Locking header bolts-
Old Mar 24, 2014 | 05:38 PM
TTOP350's Avatar
Re: header gaskets
I can't say the anti-seize would help with a soft aluminum or copper gaskets (the gaskets expand/contract so much and cause bolts to fall out if you don't tighten them every heat cycle) used those once, I'll never fight them again.
I know it does help keep bolts in with the fel-pro gaskets.
The only metal exhaust gasket I would use would be a MLS gasket IF they would fit the header ports perfectly.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
