Cheap headers for a T56 Conversions?
Old 04-24-2014, 08:35 PM
MustangEater82's Avatar
I have read up a little bit about peopel having clearanc issues with their exhaust and t56 with external slave conversion. Any thoughtS?
Should I go with mid lengths, or longubes, what works.
Old 04-24-2014, 11:02 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Cheap headers for a T56 Conversions?
I've never heard of this. Most of the issues lie with the transmission crossmember. A T56 actually allows you to tuck it up tighter because the trans is physically narrower than a 700r4 in the tailshaft area.
Old 04-25-2014, 04:23 AM
Still new to the fine details but I think on of the issues is with an LT1 style t56 it has an external slave/clutch fork that may have clearance issues. Also along with a T56 swap crossmember.
Old 04-25-2014, 07:57 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
I had this swap and had zero exhaust clearance issues
Old 04-26-2014, 07:35 AM
So no issues with longtubes/mid lengths with T56 swap crossmembers? I can use what ever brands I want for the most part?
Old 04-26-2014, 09:04 AM
Car: 91 Trans Am
Engine: 355 TPI
I don't see why not. Long tubes you might need a custom y-pipe. But other than that I don't see why you would have issues. I had shorties on mine
Old 05-02-2014, 09:22 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
The t56 slave is in a better position than the t5 so longtubes fit have no problems and shorties could care less cause they go down the passenger side
Old 05-03-2014, 03:01 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The Hedmans (the cheapest LT's) tuck higher than any of the other LT's that Im aware of... and they fit fine.
The crossmembers are the only problem, but that's the same with an automatic. As was mentioned earlier, the T56's are physically narrower so it's a lot easier to tuck up exhaust piping beside them.
I dont know of ANY long tubes that don't fit T56's, and T5's are only problematic because the slave cylinder sticks out farther and is oriented the reverse direction and hits the flange of the Hedmans.
Old 05-15-2014, 10:43 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
no issues with longtubes and t56 here either. i went with the hawks crossmember and my dual 2.5 in exhaust is farther from the ground than the stock 6 cylinder exhaust was when the car was born
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
nugentcj
Camaros Wanted
12-22-2015 02:58 PM
88 TA GTA
LSX and LTX Parts
09-11-2015 11:31 PM
Stryker412
09-07-2015 09:11 AM
tonys91rs
09-02-2015 07:07 PM
Quick Reply: Cheap headers for a T56 Conversions?
