Header to spark plug boot clearance
Old May 12, 2014 | 11:49 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
What is an acceptable distance between the spark plug boot and the header? I have 882 heads, hooker 2460s, AC R45TS plugs and 90* boots and there is maybe a half inch of clearance on some of the plugs.
Old May 12, 2014 | 01:03 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Header to spark plug boot clearance
I have about an inch clearance with mine, but they're angle plug heads, never had issues with them. I don't know about half an inch though. Do you have the ability to manipulate them any? ziptie them a certain way or something to get you more clearance?
Old May 13, 2014 | 01:37 PM
drdave88's Avatar
Engine: 6.0L
These arent angled plugs, these are straight, so the end of the boot is right at the header.
Old May 13, 2014 | 02:08 PM
Car: 1983 Z28
I know, I was saying that mine were. I would be worried with them being so close, if your headers are ceramic coated or wrapped you may be alright.
Old May 13, 2014 | 02:38 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Mine aren't too close, but I bought these for added comfort. Plus they look killer with the MSD wires and Jet-Hot coating of the headers.
DEI Protect-A-Boots
*Note* I had to remove the metal ring inside the boot covers to get them over the thick boot of the plug wires as I have them snug on the 90* boot about 1/2" from the head. They won't come away from their positions unless you pull on them nicely. Safe and secure from the heat.
Old May 13, 2014 | 03:33 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Some wires with ceramic ends might help as well.
http://www.ebay.com/itm/Accel-9033C-...e98e36&vxp=mtr
Old May 13, 2014 | 03:51 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Funny. A part from Accel, sold by Jegs...on eBay. Those look nice though.
Old May 13, 2014 | 04:11 PM
Joe Tag's Avatar
accel makes header plugs that are about 3/4" shorter than standard. Those and angled boots, I have no issues with my 2460s.
Old May 13, 2014 | 08:03 PM
DynoDave43's Avatar
When I worked in a Chevy dealership years ago, and GM still made motorhome chassis, we were a servicing dealer. These (wires with ceramic boots) were popular with coach owners, as burning wires was a common problem (along with overheating/warping exhaust manifolds and headers).
In applications where you need them, they are very effective.
Old May 14, 2014 | 10:48 AM
drdave88's Avatar
Engine: 6.0L
Happen to have a part number for those plugs? I do plan on getting some sort of a boot cover as well.
Old May 14, 2014 | 11:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I have a few near 1/2" from downpipe that is wrapped and boot protected. No issues. Thats a very hot environment too being a turbo car
Old May 14, 2014 | 11:53 AM
Joe Tag's Avatar
Fortunately, I still have the box. Only number on it is 0576S-4. Easy enough to find at A/Z or advance, right behind the counter in their "performance" section.
http://www.ebay.com/itm/Accel-Spark-Plugs-0576S-4-Shorty-Resistor-Race-Plug-4-Pkg-/400281063172?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d329c4f04&vxp=mtr
Old May 14, 2014 | 12:39 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have AFR 195 heads with straight plugs.
Ed Quay 1 7/8 long tube header.
Regular length spark plugs.
I use 90 degree boots and have zero problems.
No wrap or heat shielding either.
Old May 15, 2014 | 01:10 AM
racerx520's Avatar
i have new aluminum heads with angled plugs, went through my local napa store, first they gave me a set of wires for an older style distributor cap, and the second (which i was on the phone with MSD saying its a direct fit for my 87 t/a) were all straight boots, although 8.5mm wires, i had to bend each boot with a pair of channel locks and some of the boots are still barely touching the headers. should be an interesting smelling first startup lol. if these boots go, i'll have to find another set of wires i guess lol, but for now i'm not gonna let my $80 bucks go to waste lol
Old May 15, 2014 | 12:09 PM
drdave88's Avatar
Engine: 6.0L
I'll throw them on and see how they hold up with some boot protectors. Thanks for the info guys.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
