Out with the 3" and in with the 4" cat back setup
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Well guys , I have been running a 3" cat back for awhile and have been contemplating going to a 4" setup due to being turbo charged. Afer tlooking at all the options like Mufflex and the Sinister setup i did some figuring on what piping i would need and placed the order from Summit Racing.
Total with shipping the piping i needed was 171.00 without the muffler vs the $449.99 For the sinister setup and $600 plus from Mufflex.
not sure if i am going to run a muffler due to the turbo quieting things down some..
.I just removed my 3" setup a few hours ago and will post up progress of the 4" setup as i go. If things go well i should have it done by Sunday. wish me luck
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Re: Out with the 3" and in with the 4" cat back setup
good deal, i'm reworking the exhaust on my car this winter, trying to decide on 3.5" or 4". building it yourself will get the results YOU want! looking forward to some pictures and video.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I bought the sinister kit.
Knowing what I know now, and learning how to weld, I should have bought the pipes and welded it myself.
Although the y-pipe is the hardest thing to do
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Big pipe = big volume. Get a muffler. You'll be glad you did later.
have to run a straight thru muffler if i do.....chambered mufflers on a turbo car are a no no
Here is some progress from tonight
a few more
need another 90* bend and some band clamps and i can finish the rest
Car: 1992 Camaro RS
I used to run a dynatech splitflow, basically a Borla XR1 knockoff. I got rid of and got a Hooker Aerochamber... A lot calmer at cruise, still ****ing loud though. This is a 3.5" system, NA, though. Not apples to apples, but big pipes just make a LOT of noise.
nice....the only way i could run a muffler is to put it where the converter is supposed to go
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Wow, I can't see that taming the dB at all! Is that the Dynaflow or the Hooker?
Car: 1992 Camaro RS
It's just as loud at idle and WOT as the splitflow was, but it's significantly calmer at part throttle cruise and mild acceleration.
This is the Dynatech splitflow it replaced. If you look at a Borla XR-1 you'll see a nearly identical setup.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
If your upgrading mightiest well go 4" and would really complement the 6.0 no need to upgrade again
4" vband on the merge pipe and start of the intermediate pipe
Car: 91 Z28
Engine: 6.0L LQ9
Badass355ciz28, looks like it's coming together nicely!
3.5" aerochamber only flows 441cfm, i got this info directly from holley. if the made a 4" that would be great. i love the sound of my crossflow aerochamber, but if i redo my exhaust i want something that will flow the cfm that my engine needs, so it's going to be maxflow or ultraflow for me.
Need to figure out where I'm gonna put a muffler
Installed a bullet muffler in the I pipe
Been driving the car with the setup and loving the tone. Ended up putting two bullet mufflers on it. One where the converter goes and one where the original muffler goes. plenty of ground clearance and no rattles either. fit over the axle no problem as well.
Here's a pic
Another
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I used a magnaflow muffler, straight through. 4" Mufflex with Hooker 1-3/4 LT headers unleashed an additional second off my 1/4 mile and added 10 mph. I took off a 3" Flowmaster system with 1-5/8 headers. I think it sounds pretty good
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Looks good! I used to run a bullet plus an ultra flo on my old duals. Real quiet but lots of flow. Now single 5" with diesel truck muffler, alittle louder but the sound is awesome
thanks fellas...it has a nice crisp sound....once I get time ill tke a few vidoes and post them up.
