hedders
Old Jul 23, 2014 | 09:55 AM
tri power's Avatar
hedders
looking at headman shorty style an putting true duals on 92 Camaro any one tried this
Old Jul 23, 2014 | 12:31 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: hedders
I'm sure it's been done. But why bother with shorty style if you are going to true duals? True duals won't leave much ground clearance on these cars...and if you are going to sacrifice ground clearance for that you may as well go with the better flowing long tubes.
Old Jul 23, 2014 | 12:50 PM
Joe Tag's Avatar
Re: hedders
I had true 2.5" duals on my car when I bought it. They were run the same route as a single with no ground clearance issues. Car was driven in rural WV on rutted "holler" roads regularly. Stock ride height and tire size. The shop I worked at did dozens of these back in the day.
Old Jul 23, 2014 | 02:23 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: hedders
yeah if you want duals just go longtubes
Old Jul 23, 2014 | 04:04 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: hedders
If you want duals and shorties you can do something like this but skip the merger
Old Jul 24, 2014 | 07:29 AM
tri power's Avatar
Re: hedders
Car is back halved
Old Jul 24, 2014 | 08:12 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: hedders
i've got hooker shortys with true dual 2.5" pipe, an h-pipe, and the exhaust goes all the way out the back. i have no clearance issues.
Old Jul 24, 2014 | 09:17 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: hedders
The reason to run shorties and duals if if you have an Auto car, long tubes and the way they need to be routed won't fit with stock ride-height.
Old Jul 24, 2014 | 09:19 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: hedders
You still want the merger though in the form on an X or H pipe don't you?
If that's the case, why run duals at all past the X or H pipe?
88camaroRS
Dec 2, 2001 05:11 AM
Changa2
Jul 30, 2001 06:24 AM
Trigger84
Apr 21, 2001 03:58 PM
burnoutrpm
Aftermarket Product Review
Mar 2, 2001 01:02 PM
