Header collector leak
Old Sep 9, 2015 | 07:30 PM
bamaboy0323's Avatar
What is the best/easiest way to seal up the header collectors where it meets the Y-pipe. I have edelbrock tes headers and I have leaks and need to seal them completely because my new exhaust systems sounds like crap. Thanks.
Old Sep 9, 2015 | 11:29 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Header collector leak
If it uses a gasket. Throw away the paper gaskets and go with the dead soft copper gaskets. I had a set of summit brand dead soft copper ones for 8 years on mine. Not a single hint of a leak. I think they were $10 for the set when I bought them
Old Sep 10, 2015 | 08:04 AM
On my TES (L69) there is no gasket on the pass side at all. The header outlet mates to the EFE valve, and its ball flange seals to the Y-pipe. A gasket could possibly be used if necessary between the header & EFE, if so it would be a simple flat 2-1/2" w 2 bolt holes. On the driver's side, it takes a standard 2-1/2" donut if memory serves. The one for a typical big block is perfect. Ask for the donut for about a 76 truck 454. The all-metal type usually works best. Since you don't say what kind of car you have I can't be sure you have the same EFE valve arrangement.
Old Sep 10, 2015 | 06:58 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Go with copper gaskets! I've had them for 9 years now and never had a leak. You can actually reuse them many times.
http://www.summitracing.com/int/parts/sum-620130
http://www.summitracing.com/int/parts/sum-111406
Best of luck!
Old Sep 12, 2015 | 12:14 PM
He doesn't have that stupid leak-everytime 3-bolt crap. (thank goodness) He has something that actually has a prayer of sealing, instead. Those guaranteed to leak and fail 3-bolt gaskets don't apply.
Here's my TES (L69). Again, since the OP didn't tell us what car he has, I can't be sure his match mine exactly, but the difference, if any, will be on the side with the EFE valve.
Note how you can clearly see on mine, NO LEAKS WHATSOEVER, with no gaskets except for the donut on the driver's side, which you can see the accommodation for in the driver's side Y-pipe flange. As said, he can put a gasket between the header and EFE valve (or spacer if he has that) if he wants, but it isn't needed.
Attached Thumbnails Header collector leak-tes-y-pipe-drvr   Header collector leak-tes-y-pipe-pass   Header collector leak-tes-headers-both-sides
Old Sep 12, 2015 | 01:39 PM
Hey guys, I have a 92 Camaro tpi l98 with edelbrock 6872 headers so I only have 2 holes.
It appears the shop that made my custom Y pipe used my old rusted flanges that I had on the car(I just bolted this up because I didn't want it to be super loud on the way to shop) Anyway, the old rusted 1's are in terrible shape and I assumed since this was a custom y pipe that all of the pipe would be new.
I don't want to get new headers or a new y pipe I just want to seal these up. I have installed the donut gaskets and that helped some but still have leaks at the same spots.
Old Sep 12, 2015 | 04:19 PM
TES came with its own Y-pipe. It's not all that great (TES in general isn't) except that IT FITS. Sounds like your car isn't the first home for that set, and it didn't get the whole set, besides. Being "custom" all bets are off as to what will fit, why it leaks, etc.
Pics would help.
Old Sep 12, 2015 | 07:14 PM
What are some other headers that are shaped like the edelbrock's. I'm beginning to think it's the headers themselves.
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Street Lethal
Sep 7, 2015 01:09 PM
