Rotten Egg Smell
Old Jan 2, 2002 | 08:27 AM
1BADAZTA's Avatar
Rotten Egg Smell
I get this rotten egg smell from the exhaust, correct me if i'm wrong , but doesn't this tell signs of a partially clogged cat problem? Need some 2nd opinions.
Old Jan 2, 2002 | 10:27 AM
Gta-Paladin's Avatar
I concur
Old Jan 2, 2002 | 01:42 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
The smell is completely normal,mostly under humid weather conditions!
Tells you your cat is working fine,really!!
Old Jan 2, 2002 | 11:08 PM
nonon I think it's a clogged cat
Old Jan 2, 2002 | 11:11 PM
robbob's Avatar
The smell comes from excess sulphar in the fuel from what I 've been told.
Old Jan 6, 2002 | 06:49 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
The smell is worse with cheap gas which has a high sulfur content - like Petro Can for example.
I don't believe that it is definetly an indication that the cat is clogged because when I changed the cat it still smelled like something died in there even when the cat was brand new and could not have been clogged yet.
Old Jan 6, 2002 | 07:49 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I have no cats on my car and whenever I run sub-premium gas I get that smell.
Old Jan 11, 2002 | 08:20 PM
camaro 22's Avatar
So no one knows for sure what this smell is caused by? I have the same smell from my exhaust, and it's horrible. How can you get rid of this smell?
Old Jan 15, 2002 | 08:27 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
i remember a dream i had the other night. It went something like this................ I had a truck that had that same rotten egg smell, so i replaced the cat with a hollow cat, and *poof* the smell went away. I also hollowed out the dual cats on my '91 Z. ........... but I would never do that, because it's illegal, right?
Old Jan 17, 2002 | 01:34 PM
mtccl's Avatar
It has to do with the octane rating in the gas. Run a couple of tanks of premium and maybe even a can of octane boost and see if the smell goes away. Good Luck!!
Old Jan 19, 2002 | 08:00 AM
DiecastZ28's Avatar
Put an air freshener in the exhaust, maybe like cherries or strawberries.
Old Jan 23, 2002 | 08:11 AM
75/92 Birdman's Avatar
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
I have the same smell and it is TERRIBLE! I have never run anything but premium in my car and it has always had this smell.
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
