need help with a gasket?
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
i have a 88 gta
I have flow tech shorty headers y pipe and magnaflow cat back exh
I have had the headers for 3 years
and I cant seem to keep a 2.5" diameter 3 bolt gasket in it where the y pipe connects on the headers
there are 2
the remflex ones just blow out within weeks
I don't know what to use
does anyone have a idea
I saw some mr gasket soft aluminum ones for it ????
ty!
there are 2
ty!
Re: need help with a gasket?
https://www.summitracing.com/parts/sum-672325
https://www.summitracing.com/parts/flo-15938
Get rid of that worthless 3-bolt crap and put something else on there that might actually work.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have had good luck with solid aluminum gaskets like these.
https://www.speedwaymotors.com/Flowt...ch,140847.html
Yeah the problem with the 3 bolt stuff is that it's very difficult to get the flanges perfectly parallel so you get even clamping force. Then the junk warps when it gets hot......
Either weld flex joints into the Y pipe or ditch the 3 bolt system. You will have nothing but problems till you take one of those routes.
GD
GD
Right: the 3-bolt crap is GUARANTEED FAIL. The worst thing about it is, ONE TIME of overtightening the bolts, and the whole thing is permanently destroyed, for all time; once that is done, it will NEVER EVER seal again, no matter what gaskets you use. The damage is PERMANENT IRREVERSIBLE and IRREPARABLE: it's impossible to replace the thing that warps, namely, the loose piece on the header side that spins. Worst design EVAH. Always has been, for as long as I've been dealing with it (over 40 yrs), and since long before that.
Cut that stoooopid worthless crap off and weld in what I linked you to. You won't believe how much better it is.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Or get rid of all that worthless crap and get these
https://www.thirdgen.org/forums/atta...w-dcp_1340.jpg
Knight350
Apr 1, 2003 11:41 AM
bhaas
May 9, 2002 01:22 PM
IROC315
Nov 28, 2001 06:29 PM
Wayquick4u
Nov 13, 2000 05:05 PM
Wayquick4u
Nov 13, 2000 01:59 PM
now your chance before there gone forever.
