4th gen loudmouth on 3rd gen.
Car: 89' Firebird Formula 350
Engine: 5.7L, TPiS MiniRam, 195 Alum Heads.
Axle/Gears: 3.08, 9bolt
will a 98-02 slp loudmouth cat-back system fit in an 89 with 3" slip fit vin "8"?
Re: 4th gen loudmouth on 3rd gen.
Physically fit into the exhaust, probably after you adapt the end at the catalytic converter, and monkey with the hangers. Bolt right up with zero fab? Probably not.
Can deal with the hangers. have a torch and welder. Just not sure about the bends in the pipe to match the tunnel in the floor pan.
The 4th gen exhaust from the middle back, is pretty much identical to thirdgens. The way they route the manifolds, y-pipe, and cat(s) is unique. Should be easy enough to adapt the front to the middle, the back will fit fine.
Car: 89 Firebird
Engine: 355 TBI
I've seen a few Third gens around here with the 4th gen Loudmouth and Texas Speed Rumbler. My 3in exhaust system in my bird is actually 4th gen itself.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Just found an unused cat-back loudmouth system online for a 98-02. Arrived yesterday. Have other work to do before the car is ready as its been stored for about 8 years but will post some picks later. Thanks for the input.
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
I have a 4th gen LM2 on my 87 Formy. Unbolt the two rear mounts, swap sides, drill a hole in the rubber on the drivers side, voila!
kclipperton88gta
Oct 30, 2000 07:39 PM
GOFASTER
Sep 15, 2000 04:27 PM
