How to Remove Smog Pump and A.I.R Tubes
Car: 1991 Camaro RS
Transmission: T5 manual
Need help with removing my smog pump and A.I.R tubes on my exhaust as I'm trying to run Hi-Flow cats and a better exhaust system. I want to remove weight and make the engine bay look cleaner. Do I have to get a new radiator? What all do I need and where can I get the A.I.R plugs for the manifolds? Also, I don't want to get a delete pully so how would I have to go about doing that and running a different belt?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to Remove Smog Pump and A.I.R Tubes
inverted flare plugs for the manifold. The air pump has zero to do with the radiator.can run a shorter belt or there are two different bypass pulleys available.
Car: 1991 Camaro RS
I asked about the radiator because there seems to be a hose from the radiator that one of the pumps attaches a line too. I'll look more at it and figure it out but thanks for the info
Engine: Lb9
Transmission: M20
Search the forums, lots of info!
ACDelco #935K6 + your Cat converter(s) need a plug of some sort or be replaced.
https://www.thirdgen.org/forums/tech...p-removal.html
https://www.thirdgen.org/forums/tech...ml#post6367775
https://www.thirdgen.org/forums/tpi/...-diagrams.html
https://www.thirdgen.org/forums/tech...e-without.html
https://www.thirdgen.org/forums/exha...p-removal.html
... and so on
... and so on
Engine: Lb9
Transmission: M20
Not sure what your referring to about a heater hose.
Car: 1991 Camaro RS
I may be mistaken about it but I'll look into it when I get back home. It's kinda hard to drive it with my master cylinder clip for my clutch (little plastic thing that attaches the clutch pedal and master cylinder together) keeps breaking and making it where I can't shift gears. Really annoying thing.
Car: '89 GTA
Engine: ZZ6TPI
There is no cooling system connection to the AIR system.
You can cap the existing air tubes at the exhaust manifolds with a rubber radiator hose cap and a band clamp. Leave the check valve in place and just cap the end where you removed the rubber hose.
Some have run a shorter belt after removing the air pump instead of buying a bypass pulley. I don't know the belt length needed, but there are many posts about it.
