2460 headers
Old May 4, 2021 | 09:13 AM
rumpity_z28's Avatar
2460 headers
Can anyone that has these headers installed please snap some pics of the passenger side clearance between the tubes and the frame rail? Mines touching 🤔
Old May 4, 2021 | 08:52 PM
Re: 2460 headers
Old May 6, 2021 | 11:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 2460 headers
Here is mine I would guess you have a motor mount that needs replacing
Old May 6, 2021 | 01:58 PM
Re: 2460 headers
Ok thnx I did have the subframe out for sandblasting and painting. I must have messed up installing it. It looks like you have close to and inch of clearance there.
Old May 6, 2021 | 02:29 PM
midias's Avatar
Re: 2460 headers
The two engine mounts are not the same I am not sure the concquinces of getting them backwards but that might be it
Old May 6, 2021 | 02:34 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 2460 headers
Mine has about enough space to put my hand and not touch header or frame rail
Old May 6, 2021 | 09:02 PM
Re: 2460 headers
Ok ill check that too thnx, any suggestions on replacement motor mounts? poly versus stock rubber
Old May 28, 2021 | 05:32 PM
Re: 2460 headers
Well this is what I found, and the k member is caved in where this sat.
Old Jun 1, 2021 | 03:43 PM
midias's Avatar
Re: 2460 headers
That would cause an issue for sure. Lets us know how the replace goes
Old Jun 2, 2021 | 10:15 PM
Re: 2460 headers
yeah i have another k member coming so ill throw up a post when its all painted and installed again
Old Jun 26, 2021 | 12:09 AM
Re: 2460 headers
This is the old k member
This is the new one with the angle from the old crossmember put up to it for comparison
These are the locator pins on the old k member center to center measurement
And this is the new k member measurement
Old Jun 26, 2021 | 12:12 AM
Re: 2460 headers
Old Jun 26, 2021 | 12:16 AM
Re: 2460 headers
So this is why the headers were way off 🤔 and I built my own y pipe using mandrel bends which may need some tweaking after I get this fixed
Old Jun 26, 2021 | 09:51 AM
midias's Avatar
Re: 2460 headers
Looks like you're going to have to make a cut or two to your y-pipe but I'm glad you found the issue who knows what other weird things this could have caused
Old Jun 27, 2021 | 08:30 PM
Re: 2460 headers
And done
Looks much better
I had to use a hydraulic ram in between the rails and push it out a little over 1/2" for the new k member to line up
Old Jun 27, 2021 | 08:49 PM
midias's Avatar
Re: 2460 headers
Looking good
383RS
Aug 16, 2008 09:13 PM
J's T/A
Feb 18, 2006 01:41 AM
94zsson
Aug 6, 2004 08:48 AM
Dragula
Aftermarket Product Review
Feb 22, 2002 07:06 AM
