Header Recommendation
Old Nov 25, 2021 | 07:27 AM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
I have a 83 Z28 with a 87 IROC-Z 305 TPI which I have upgraded to the 90-92 Speed Density system. Presently, I have the SLP stainless steel Y pipe and the 3" stainless steel system back. I never bought the matching headers but now I wish I did. I am thinking about losing the stock exhaust manifolds and going with a good set of headers. However, I don't want to ditch the stainless steel system. Does anyone know if anyone makes a set of headers that would match up?
Old Dec 24, 2021 | 12:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Header Recommendation
Headers and y-pipe are a matched set, so only SLP headers will fit perfectly with SLP y-pipe.
Old Dec 24, 2021 | 09:36 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You could use my headers and have someone modify the ends of your y-pipe to fit.
Old Dec 24, 2021 | 03:28 PM
Or, use Don's stainless headers & Y-pipe, and retain the cat & cat-back. Personally that's what I'd do.
Old Jan 2, 2022 | 11:38 PM
silverstang84's Avatar
Car: 88 IROC
Don, how much for a header/y pipe set??
Old Jan 3, 2022 | 10:51 AM
Dyno Don's Avatar
Send me a PM
Old Mar 20, 2022 | 11:42 AM
HDuty463's Avatar
Car: 1991 Z28
Engine: 5.7
Dyno Don,
What are your headers made of? I have a set of hooker's on there now that are rusted over. They have been on the car since 1994. Been throwing around the idea of taking them off, get sandblasted and then paint them with high heat paint.
Old Mar 20, 2022 | 03:41 PM
I'm not Don; but, I'll answer this part.
COMPLETE waste of time and money.
NO paint will hold up long on regular steel. ESPECIALLY not after sandblasting, which leaves the surface entirely covered in microscopic pits which there is NO WAY IN HELL to get paint all down into every one. Which then of course, if rust gets up underneath ANY of the paint WHATSOEVER, it'll just blow the paint RIGHT OFF. Just, altogether the wrong thing to do, on headers. Might work on some other things; but definitely NOT headers. Never has, never does, never will.
You'd have better "luck" if you sent em off to get ceramic-coated. They'll take care of the sandblasting and cleanup and whatnot, to THEIR process' satisfaction.
Again, I'm not Don, but AFAIK, his product is stainless, and is either ceramic-coated by default (the ones in his photo are), or he makes it available. Or if not, you can have it done yourself. Ceramic over stainless is BY FAR the best recipe for headers.
Throw the old crappy wore-out ones in the trash and move into the 21st century.
FireDemonSiC
Jan 21, 2009 09:58 AM
Matthewy8
Dec 7, 2004 10:22 PM
1bad406rs
Nov 3, 2004 02:46 PM
bluegrassz
Aftermarket Product Review
Feb 7, 2002 11:18 PM
