Suggestions on primary header size for modded 305
Old 12-10-2023, 09:08 AM
Chris_Formula's Avatar
Hey folks,
short question:
Im searching for headers for my 88 formula. The 2055 hooker arent avaiable at summit. So im looking around and found american racing headers with 1 3/4" primary tubes. Is it overkill for my engine or would you suggest going larger than 1 5/8" (hooker 2055 f.e.)?
There is a large debate about this topic and I know either 1 5/8 or 1 3/4" would be the way.
Background and technical data:
-rebuilt 305 bored .030" over
-Trickflow 175cc heads
-10.2:1 static, 9,5 DCR
-206/212 in/ex @ .050 cam
-.512"/.520" lift @ valve
-3" exhaust, but with "ported" exhaust manifolds till yet.
-ported tpi manifold, but soon want more rpm (swap to pro flo 4 xt)
What do you guys think?
Im pretty sure to go for more rpm in future.
Greetings,
Chris
Old 12-10-2023, 09:22 AM
Firechicken82's Avatar
Car: 82 TA
Engine: Zz430 clone
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Suggestions on primary header size for modded 305
A 1 5/8 will be fine and may be better w the 305/tpi. I bet you'll make better torque w that setup. I have a pro flo xt w a 350 and it likes to rev more. I had Edelbrock tes 1 5/8 headers and switched to dons 1 3/4. Didn't do a back to back dyno so I can't say power wise. I don't think my seat of the pants dyno is capable of telling. The pro flo makes great power either way. I'd consider trying to get a set of dons headers while he's still doing them if you're gonna try and go 1 3/4.
Old 12-10-2023, 09:52 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Go here to get on the list...
https://www.thirdgen.org/forums/exha...ml#post6518997
dmccain (12-12-2023)
Old 12-11-2023, 04:13 PM
83 Crossfire TA's Avatar
Shorty (really these used to be known as 3/4 length and there are shorter headers) are more about HP (overall flow) and less about torque (tuning that flow) than long tube headers. You're about in the middle with that combination, long tube 1-5/8" headers will get you the best low end and mpg, 1-3/4" shorty headers will likely make more HP, less torque, 1-3/4" long tubes will likely be the best of both worlds. This is all assuming that everything else matches. You'll likely not have enough airflow with the TPI manifold to really take advantage of the 1-3/4" headers.
Not a clear "do this" answer but not really a clear "I'm doing this and I want this" question.
Old 12-12-2023, 08:05 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Get DynoDons
tchernobog
03-31-2009 05:01 AM
anesthes
08-07-2008 07:03 AM
greezemonkey
34
03-10-2007 04:28 PM
patgta
10-31-2006 12:56 PM
DTL504
06-12-2004 08:03 AM
Quick Reply: Suggestions on primary header size for modded 305
