Headers Question
Old Jan 26, 2002 | 11:24 AM
chevyo3's Avatar
Car: 87 Camaro Sportscoupe
Engine: LG4
Headers Question
I have a 305 LG4 engine in my SC Camaro. I have heard one of the first things to do to get more power is to remove the stock manifolds ,and bolt on some headers. If done do I need to change Y-pipe ,and rest of exaust? I just replaced current exaust from catyiltic converter back about a year ago. What type of headers you guys suggest. Need more power asap. lol
Old Jan 26, 2002 | 01:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, headers should be your first mod. And you'll need a new y-pipe, but most headers come with a new y pipe. And it can bolt to your stock cat-back. If you plan on keeping the LG4 and not doing to many major mods on it, then the Edelbrock TES headers should be fine. But if in the future you plan to squeeze all the HP you can or switch to a 350 then SLP is the best, but of course you pay for the best.
Old Jan 26, 2002 | 01:51 PM
z28-92's Avatar
Just curious. I have a 92 z28 with the 350 and the g92 option and was also looking at installing headers (dual cats were already removed and straight pipes welded in its place). What will be the net result of adding headers. Will it increase the power through the entire rpm range or would it shift the power curves or would you see the bigger improvements in the higher rpm's.
thanks
Old Jan 26, 2002 | 02:25 PM
Car: 99 Formula
Axle/Gears: 342
I don't really know the true answer to that. But the exhaust on our cars, manifolds and y-pipe are really restrictive, so I would guess it would be the entire rpm band and allow better high rpm breathing. Headers are usually good for about 10-15 hp, which may not be a lot, but doing other mods first won't really benefit you until you do headers and cat-back for your engine to breathe.
Old Jan 29, 2002 | 05:52 PM
chevyo3's Avatar
Engine: LG4
Great. I'll try the Edelbrock TES headers you recomended. When you say cat-back do you mean the catylitic converter back? I thought about taken the converter off. Not to wooried here in PA about emmisions testing. I also thought about changing intake manifold to a Edelbrock performer. Would I have to change cam ,and carburator also? I am working with a tight budget.
Old Jan 29, 2002 | 06:23 PM
Car: 99 Formula
Axle/Gears: 342
You won't have to change carburetors, but you might have to buy an adapter to fit the intake to the q-jet. A cat-back hooks to the cat. You could just have a pipe in place of the cat.
You won't have to change the cam either, unless you want to get rid of the peanut cam.
Old Jan 29, 2002 | 06:45 PM
chevyo3's Avatar
Engine: LG4
When you say cat. do you mean catalytic converter? What kind of a gain in HP could I expect by changing intake ,and adding headers?
Old Jan 29, 2002 | 06:55 PM
Car: 99 Formula
Axle/Gears: 342
Yeah cat, is short for catalytic converter. I would think with intake and headers maybe around 20 hp. If I were you order the new Edelbrock Performer EPS, it's new with higher HP increases over the existing Performer, at $30 more.
Old Jan 29, 2002 | 07:28 PM
chevyo3's Avatar
Engine: LG4
Thanks for the info. Now do you know any good sites to view those parts you suggested. Need to get prices.
Old Jan 29, 2002 | 09:39 PM
Car: 99 Formula
Axle/Gears: 342
Go to www.summitracing.com or www.jegs.com . I prefer Summit, guess cause that's who I first bought from. Just do a search for headers and intakes. The headers are going to run $313.
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
