Hooker headers
Old Mar 17, 2002 | 01:42 AM
TBIWorks's Avatar
Hooker headers
I just bought an f-body w/ hooker headers and some crappy homemade y-pipe. I have an exaust leak, what gaskets do I use if it is at the exaust ports. Will any header gaskets for small block chevy work. please post a part number for me(if you are sure). Thanks guys....Patrick
Old Mar 18, 2002 | 01:51 AM
Tas's Avatar
Tas
Hooker headers will either have the ball flange connection like my 2055 that don't need gaskets or they will need standard 3" header collector gaskets. Do you have old gaskets to compare?
Old Mar 18, 2002 | 09:48 AM
TBIWorks's Avatar
I guess what I need to know is what exaust gaskets to use at the exaust ports on the heads, not at the collectors. Do I use stock manifold gaskets?
Old Mar 18, 2002 | 11:18 AM
Tas's Avatar
Tas
well the ones that came with time were 1-5/8 square opening cardboard gaskets. I measured them and got some feltpro's insted for $15. If you have 1-5/8" headers then you can do the same.
Old Mar 18, 2002 | 02:55 PM
Steve89GTA's Avatar
Tas, how do you like the 2055 Hooker headers? Did you have to raise the motor for install? How about bend brake lines or remove the steering shaft or mess around with the starter?
Thanks, I'm looking to buy these headers soon.
Old Mar 18, 2002 | 08:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am also looking to buy the 2055's. Can these be installed in your driveway with just jackstands and simple tools. Did everything fit okay?
Old Mar 18, 2002 | 10:27 PM
Tas's Avatar
Tas
They go on next week when my friend has time to help me (spring break). We did the whole exaust on his Mustang plus a Trick Flow intake, and ignition, so he owes me
Old Mar 18, 2002 | 10:36 PM
Steve89GTA's Avatar
Let us know how it goes man!
Old Mar 19, 2002 | 08:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use Felpro 1404 gaskets at the heads. Read my response to your other post about the y-pipe.
redformula88
Oct 14, 2015 06:08 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
