Hooker lt's, I need short plug??
Old Mar 17, 2002 | 10:08 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I need a shorty plug for #7, cant find an accel for my AFR straight plug heads, anyone know of any other makers of short plugs??
Old Mar 17, 2002 | 11:09 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
You are not alone..........
I had this problem many moons ago when I installed my Hooker LTs on my 383 with STRAIGHT plugged AFR 190 heads!!
Do an archive search here on "Shorty Plugs" to see the answers!!!
Old Mar 18, 2002 | 09:43 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Phil, would happen to remember the plugs you use? Also what does your car weigh and have you lightened it up any? thanks for any info
Old Mar 19, 2002 | 12:10 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
My car weighes 3076 lbs. Aluminum heads and fiberglass hood were the most weight saving mods done. Car is light for some reason. It's a 5 speed too, they are always lighter than autos.
I use AC Delco plugs. My number seven plug is 'custom' made by yours truly..............it's a very short plug I made from a standard AC Plug for my AFR heads.......
http://www.geocities.com/cfrios/Phil...l?996948051310
Old Mar 23, 2002 | 11:17 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Phil, I am in serious need of those plugs, can you help me out?
Old Mar 24, 2002 | 09:24 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Thats odd i have AFR's on my 388 with Hooker Long Tubes and my plugs are all the same!! Not using a short one anywhere
Old Mar 24, 2002 | 11:57 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Phil, I like your setup on your site. It looks like the system I want to do on my Z except that I must use cats. Is it possible (read enough room) to use LTs with dual cats attached to the collectors then into a 'Y' pipe to a single cat back like seen on some of the LS1 f-bodys. The factory after cat 'Y' pipe looks so inefficient. which is why I'd like to try to engineer my own system maybe using something like Flowmasters 'Y' pipe but on a 3 1/2" catback system. This would be something I would have to fabricate since no one makes this type of system. It may be more efficient than shorties and the stock cat system layout if room permits.
Old Mar 25, 2002 | 08:06 AM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
slush, must be nice, you must have the angle plug heads.
Old Mar 25, 2002 | 10:32 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Sorry for delay......
Coxy,
Sorry, I don't get on here enough anymore. Send me an email: parios@yahoo.com
I can make you a short plug if you like.
Slush,
YES, it is possible, in fact, the shop that made me my muffler setup said he could do just that. He showed me some "NEW" Random Technologies CATS that were 3" in/out and very small. They could easily be used just after each header collector, before the y section. Call RT or check their site for more information, I don't know the part number. I don't have any CATS on my car nor do I plan to add them........
Good Luck, Phil
evilstuie
Feb 28, 2016 03:33 PM
gixxer92
Sep 1, 2015 04:32 PM
Bryan F
Aug 27, 2015 07:28 AM
tricky1
Aug 23, 2015 01:17 PM
Bryan F
Aug 18, 2015 02:28 PM
