Does anyone know the temperature of an exhaust pipe?
Old Apr 7, 2002 | 10:25 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Just looking for a roundabout temperature. It can be in Celcius, F, Kelvin, etc. And if anyone has greater information, what is the air temperature within 2" from the outer side of the pipe?
Old Apr 7, 2002 | 10:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A header pipe or the I-Pipe part, I would say headers get around 1200*, as far as the I-pipe no clue. Touch it, and maybe you can take a guess, .
Old Apr 8, 2002 | 03:17 PM
MikeS's Avatar
I don't know the temps, but I bet one of those "point and shoot" style thermometers would work great to find out. Also, I don't know how much they cost. So, that's about all I know (or don't).
Old Apr 8, 2002 | 03:20 PM
Car: 99 Formula
Axle/Gears: 342
I think they're a couple hundred, but most only go up to 600* I think.
Old Apr 8, 2002 | 03:24 PM
MikeS's Avatar
Nevermind then. Now that I think about it though, the high temp spray paints have temperature ratings 400 or 500 degrees F on the normal ones and up to over a thousand on the ones with ceramic whatever in them. Ok, what about this? A Fluke meter with thermocouple? Expensive too.
Old Apr 8, 2002 | 05:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
all you need to do the temp mesuremnt is 2 Thermo couples,some ice water, and a dvm, if you dont mind doing the voltage output -> temp yourself
Old Apr 8, 2002 | 05:59 PM
Car: 88 Camaro SC
Engine: SFI'd 350
you could probably get away w/ using j types too...
Old Apr 8, 2002 | 06:24 PM
BOTTLEDZ28's Avatar
Transmission: A4
id have to say real f***ing hot. i hitmy buddies tailpipe the other day changing his plate and now i have a hickey on my ear. its not bad but it wasnt a pleasent experience.
Old Apr 8, 2002 | 07:35 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Thanks for the tip. I'll use one of those point and shoot laser thermometers. Have one at work
Bubbajones_ya
Jul 6, 2024 08:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
iroczz89
Sep 12, 2015 04:55 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
