Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Floor Jack Idea
Old Feb 3, 2004 | 12:32 AM
rjmcgee's Avatar
Floor Jack Idea
Maybe I am the only one here that hates jacking the front of the car under the crossmember. The shape of the crossmember and the fact that there is usually oil on it makes me nervous of the car slipping of of the jack crushing the oilpan. On my car at least the Y pipe is just a little lower than the crossmember and I always wind up with the jack pad just barely hooking the crossmember. Plus add to this that my shop floor is not real smooth and the car has to roll forward with the jack. There is a hole in the crossmember that is about a 1/2 inch in diameter so I turned a deal on my lathe that just slips into the jack where the pad slips in. On the other end I just made a 1/2 inch diameter stud that fits in the hole on the crossmember. I am about 260 lbs so I have to jack the car up to do anything under it, and this will hopefully save me some time and give me some piece of mind that the car will not slip off.
Old Feb 3, 2004 | 12:48 AM
85iroc04ecotec's Avatar
Car: 85 z28 (summercar) 04 cavalier (winter beater)
Engine: larry brown built 10:1 350 short block vortec heads
i know its off topic but how is your t-5 holding up to the 350s torque
Is the t-5 built
I have to rebuild mine any suggestions
Good jacking tip I usually jack up my front end on the oil pan
Just kidding im not that big of a Dumba##
Old Feb 3, 2004 | 12:09 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
that's pretty cool. I like to roll my car around on the jack, sometimes it slips.....
Old Feb 3, 2004 | 02:09 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
send me one. Mine has fallen off before and smashed the radiator.
Old Feb 4, 2004 | 04:14 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Yea i hate jacking it by the cross member to, Started to slide on concrete with wet tires
Hurried with the jackstands under the A arms and it stoped
I really like what uve made there, makes me want one Or make one on my own
We should market them togeather JK u can for ur self
Old Feb 4, 2004 | 10:41 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
pretty sweet dude.
Old Feb 5, 2004 | 10:31 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Sweet!! What did you use for stock? Aluminum? Cant really tell from the pic....
Old Feb 7, 2004 | 05:21 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Thats a really cool Idea.
I need one also.
Kory
Old Feb 8, 2004 | 05:08 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
That's a nice looking part!! Good work.
I am kinda surprised to hear of anyone having trouble jacking on the crossmember though. I have been jacking my car there for years with a 3 ton floor jack. Never had it slip even a little!! I guess I am lucky...
Old Feb 23, 2004 | 09:08 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
you must be blessed brother
Old Feb 23, 2004 | 09:14 PM
Rage13's Avatar
Car: 89 Firebird
i've never had a problem jacking it up either.. and if your working under your car you should use jack stands, don't ever trust your jack.. :nono:
Old Feb 23, 2004 | 09:18 PM
rjmcgee's Avatar
It hasn't slipped, yet.
But any how, thanks for the compliments and I must say that in the last couple weeks I have used it several times and it is alot more comforting with it on there.
Oh yeah, it is just made out of a piece of 1 15/16" steel shaft.
Old Feb 23, 2004 | 09:22 PM
rjmcgee's Avatar
It isn't an issue of it falling and squishing somebody, it's about not having it fall of the jack pad when jacking the car up and crushing the oil pan.
I haven't survived the last 10 years of logging and now millwrighting in a sawmill by putting my big *** somewhere that it doesn't belong.
Old Feb 27, 2004 | 02:50 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I had mine slip off & bend the center link into the oil pan. I was able to hammer the oil pan back in shape but the center link was FUBAR.
Old Feb 28, 2004 | 10:30 AM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
Nice to see ya Kory, been awhile.
Scoty
Old Mar 6, 2004 | 10:46 PM
jm350's Avatar
Car: Camaro 1990
Engine: 352pc. 380hp.
Transmission: 700-R4
Well, i dont believe that 1/2 inch thing will work for a long time !! All the weight of the front of the car stand on that little thing ??? The surface of the crossmember on what that thing stand, will crush sooner or later !!!
I use a regular 3 tons jack since almost 10 years on my Camaro and i never had any slipping problems. If you do it carefully you not suppose to have problems, and dont forget to use jack stands.
Old Mar 7, 2004 | 08:25 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Really cool idea- good design and workmanship!
Edit- Taking a second look, I would try to chamfer the nose (the part that actually goes into the X-member) quite a bit more, to make it easier to get lined up....
Not to take away from a good idea, though.
I have had the same thoughts as you when jacking the car up on a regular jack. Is it going to shift? Is it smashing the #$&* out of my y-pipe or oil pan? and so on...
S-D
Old Mar 8, 2004 | 05:46 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
my stock y pipe make it difficult to jack on my x-member also. I use my SFCs. I went through some old paper work and foun that the precious owner paid pver $1400 to replace the enitre exhaust system, and it was all stock!! The factory dual cats were over $800 alone
Old Mar 8, 2004 | 07:07 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Gald to hear that cuz now Im not the only one who had that problem. Only bad thing about mine was I tried to bang it out as much as I could. and my 3.75stroke crank hit the oil pan Had to pull it.
rjmcgee,
Verry nice piece. would you consider selling one? Drop me a e-mail from the link in my sig.
I have abuddy with a lathe but getting him to clean it off to use woul dbe like taking cank from a babby.
Old Mar 9, 2004 | 06:01 PM
rjmcgee's Avatar
I really doubt that there is a strength problem here.
Old Mar 9, 2004 | 10:02 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I think its more an understanding problem then a strength problem. The little tit sticking out doesnt lift the car at all, just locates the jack under the crossmember. Just slip that point into the small hole center of the crossmember so the jack can't slip out. There really shouldn't be much side force. All of the lifting force is then applied to the larger diameter below the tit. Which is actually alot more surface area then most floor jacks have on the crossmember. I know my floor jack only hits on a couple of the points when lifting my car. Maybe 2 small pressure points total. The floor jack really doesnt fit the crossmember well at all, and i'm always afraid it'll slip.
Old Mar 10, 2004 | 06:04 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
what kind of wheels are those on that car? lol i know its totaly off the subject...
customblackbird
Aug 15, 2021 10:16 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
