Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Modifying a spark plug socket
Old Feb 15, 2004 | 11:53 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'd like to do this with one of my own spark plug sockets.
Would a dremel be adequate for cutting the socket?
And what type of drill would be needed to create the hole?
Old Feb 15, 2004 | 11:56 PM
laiky's Avatar
I did mine with a sawzall. i believe a hack saw will also work. I used a cheap socket, i think that makes it a bit easier. I cut a slot on the side of mine like the one SLP sells for 20 bucks. Works great with the 1 3/4 slp headers. I also cut the box end off a wrench that fits the hex and smoothed the rough end to go with it.
Old Feb 17, 2004 | 04:42 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I did mine with a hack saw. You also have to remove the rubber ring from the inside and drill out the hole in the tope so the spark plug electrode can stick through. It works great.
Kory
Old Feb 17, 2004 | 07:20 PM
laiky's Avatar
i didn't have to drill mine.
Old Feb 17, 2004 | 10:05 PM
MikeS's Avatar
I cut mine with a cutoff wheel on a die grinder.
For the record, I had to bore out the inner diameter a bit as well.
Old Feb 17, 2004 | 10:39 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just bought a 1/2 inch drive, so I don't think I'll need to drill a hole through the metal. I used a dremel to cut it to an inch and a half long, and I will clean up the cut tomorrow. Now I need to find where I put the rubber piece.
Old Feb 18, 2004 | 06:54 AM
laiky's Avatar
i don't believe you can use the rubber piece. it will stop the socket from going completely over plug.
Also, it is very helpful to cut a slot in the side of the socket. You can get it in much tighter spots
Old Feb 23, 2004 | 01:22 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
He took the words out of my mouth. I have no problem with my SLP's on any of the cylinders, works great.
Old Feb 28, 2004 | 08:32 PM
BitchinRS's Avatar
Ok I am clueless. What is the need to do this? Just curious.
Old Feb 29, 2004 | 12:04 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
A hack saw is the necesary equipment. Some sort of clamp is needed.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
