Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
AC delete bracket ideas?
Old Mar 23, 2004 | 10:26 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I have nixed my Air Conditioning (it never worked anyway) on my '88 5.7 GTA. Now I have this giant ugly bracket for the AC pump staring at me...
I need to retain the Air pump and serpentine belt tensioner pully. Does anyone know of another bracket I can use, or the part number from GM, or???
Otherwise, it's off to the bandsaw!
Troy
So Cal
Old Mar 23, 2004 | 06:50 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
do you mean that even making your own pulley is out of the question? and you want to get rid of that whole spot? I am just trying to see what you really want to do
Old Mar 23, 2004 | 09:17 PM
TA's Avatar
TA
Axle/Gears: 9bolt
The bracket that holds the Air conditioning pump is the same bracket for Serpentine systems that holds the Air pump and the tensioner, it's all one big aluminum bracket.
When you remove the A/C pump, it leaves a big void where something is obviously missing. I will take a photo and post it, so you can see what I mean.
Troy
Old Mar 24, 2004 | 10:34 AM
TA's Avatar
TA
Axle/Gears: 9bolt
Duh?!?
Help! I dunno how to attach the photo to the post. Do you have to post it somewhere online and link, or can you drop it into the message here (doesn't seem to work)
':hail:'
Troy
So Cal
Old Mar 24, 2004 | 12:14 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
GM makes an A/C delete pulley that will bolt right in where the compressor was. Try a search for the pn#, this has been discussed before.
Old Mar 24, 2004 | 01:19 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
TA, you have a PM.
Old Mar 25, 2004 | 02:46 PM
TA's Avatar
TA
Axle/Gears: 9bolt
Thanks guys, great information. GTA, you have a PM.
Troy
So Cal
Old Mar 28, 2004 | 09:44 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
I'd have to see a pic but when i removed the a/c off my v-belt car I had the a/c bracket sticking out (same bracket that holds p/s pump) so we just removed it, cut it off nicely, filed it smooth and painted it black.
Old Mar 28, 2004 | 12:32 PM
TA's Avatar
TA
Axle/Gears: 9bolt
Yea, I'm gonna go that route, 300hpse, and cut and shape the bracket. I don't like the idea of all the extra clutter of anything not necessary, like a delete pully. I have this dream that I will be able to easily access both valve covers, because I would like the option of running a solid roller cam if I want, so I'm on a "tidy binge"...
If I can figure out how to post photos, I'll do a before and after.
Troy
So Cal
Old Apr 11, 2004 | 09:19 PM
LT1VertIroc's Avatar
Car: 2004 GTO
Transmission: 6 Speed
Gm sells the 1LE A/C delete pulley. It is a nice piece and fairly inexpensive. The PN is 10055890. If you go to buy one have this number handy cause it would take them forever to find it if you just went in and asked for it. I put one on my car and so did about 3 or 4 of my friends. Most of us polished it since its an easy piece to polish. Anyway, that should help you out.
Eli
Old Apr 11, 2004 | 09:25 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I think I've seen a few of those floating around on ebay. May be a cheaper alternative!
Old Apr 12, 2004 | 08:41 AM
TA's Avatar
TA
Axle/Gears: 9bolt
I really didn't want an AC Delete pully, I wanted to remove the entire ugly mess up there and move the smog pump valves up in that area, off the valve cover. It's already in progress, so I will post photos (if I can figure out how) when I am done.
Troy
So Cal
Terrell351
Jun 13, 2021 01:13 PM
Genopsyde
Nov 11, 2015 10:46 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
