Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Nitrous bottle blow down tube
Old Apr 4, 2005 | 06:42 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Just wondering if anyone has fabbed a blow down tube for a nitrous bottle?
Moderators, please move to the Power adder forum if need be.
I have an external thread on the bottle.
Can I just use an -8an female end and braided fuel line?
LB9GTA
Old Apr 5, 2005 | 11:19 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Anybody?
Old Apr 6, 2005 | 12:48 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I have done it, and yes that would work fine. Although, I used hard line and an aeroquip -8 AN end.
Old Apr 11, 2005 | 09:23 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
yes sir. hard or braided, as long as its exiting the chassis.
good luck.
Old Apr 20, 2005 | 11:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
exactly what i wanna do, use braided line to dressit up and run it straight down from where the rear seats would be into a hole in the floor pan.....how would one go about attaching it to the floor?
Old Apr 20, 2005 | 11:46 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
if you run braided line......
8AN X 8AN bulkhead.
or an 8AN X whatever size pipe.
you will need some flat washers to take up the slack if you are using an existing drain hole in the floor pan.
or you could just run hard tube, bend it up real nice and you wont need a clamp. it stays in place all by itself.
you can polish the aluminum tubing out pretty easy. can look like chrome, if you are into that.
good luck.
Old Apr 20, 2005 | 11:50 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thats true, but i saw someone running the braided line for the blowdown and IMO it looked amazing. depending on how i build my rear seat delete and where i mount the n20 bottle i probably will drill my own hole.
Old Apr 21, 2005 | 12:43 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
So does anyone know if I have to get a pressure release valve and the braided line?
Or is it already on the bottle?
LB9GTA
Old Apr 21, 2005 | 02:50 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
mine is on the bottle.
Old Apr 21, 2005 | 09:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
there IS a std pressure relief valve that comes on the bottle, but you have to buy a special one with the disc that has the 8AN male threads so you CAN run the blow down tube.
good luck.
Old Apr 21, 2005 | 11:00 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Thanks stage 20.
I will have to order the blow down tube rather than the braided line
LB9GTA
Old Apr 21, 2005 | 11:29 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally posted by LB9GTA
Thanks stage 20.
LB9GTA
wait! either line will work. you STILL have to buy the blow off adapter, no matter which line you choose.
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Fanatic1074
Oct 2, 2015 03:47 PM
zman1969
Oct 1, 2015 11:09 AM
dusterbd
Sep 29, 2015 08:40 AM
