Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
T-56 swap crossmember complete
Old Jun 13, 2005 | 06:09 PM
TexasLT1's Avatar
Car: '92 RS
I've been working on swapping in a T-56 for the past couple of days and finished the cross-member last night. I made it out of 1x2 rect. tubing and 1/4" thick plate. I don't have any pics right now but will get some tonight.
T-56 + Spec Stage 3 + Pro 5.0 + 4.10's =
Old Jun 14, 2005 | 06:25 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Any pics??
It may be really simple but a pictures worth a lot of words.
Old Jun 15, 2005 | 04:37 PM
TexasLT1's Avatar
Car: '92 RS
sorry about taking so long, I've been more concerned with getting the car running again than posting photos. I'll have them up tonight.
Old Jun 17, 2005 | 09:18 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I look foreward to seeing your pics.
I built one when I put my t 56 in last spring. I am thinking of building another one with clearance for long tubes. What does your's look like?
Kory
Old Jun 27, 2005 | 11:20 AM
TexasLT1's Avatar
Car: '92 RS
I apologize for taking so long, was working on my car the whole time I was home, had to wait till I was back in Colorado.
Old Jun 27, 2005 | 11:21 AM
TexasLT1's Avatar
Car: '92 RS
1x2 rect tubing. the sides are some scrap 1/4" thick channel that had already been cutdown to the perfect size I needed.
Old Jun 27, 2005 | 11:22 AM
TexasLT1's Avatar
Car: '92 RS
I used a 1" drill bit to drill the hole for the trans mount stud, then used a die grinder with a carbide bit to enlarge it when I mismeasured the cut points and had to shift it over
Old Jun 27, 2005 | 04:41 PM
Car: 88 Iroc
Transmission: t 56
That looks alot like mine. THe only differance is I used a pc of L channel with a flat plate on it for the tranny mount.
It looks real good.
Kory
Old Jun 29, 2005 | 04:12 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It looks identicle to the Skulte x-member.
What you should do is buy my coated longtubes with custom 3 in. mandrel Y-pipe and my T-56 double hump x-member. It would be a direct bolt-on for ya.
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
