Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
boxing in my lca's
Old Jun 25, 2005 | 06:36 PM
454transam's Avatar
Car: 83 fully modified trans am
Engine: 454
Transmission: 5speed
boxing in my lca's
alright so im going to box in my lca's and i was wondering if it would mess anything up if i cut the little lip off of the bottom and just made them square
Old Jun 26, 2005 | 01:19 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
No that wont mess anything up, just make sure the metal being welded in is about the same thickness as the LCA, Also Leaving some drain holes near the ends will help with getting water out, or weld them shut and dont worry about it And dont forget to get some new bushings
Old Jun 26, 2005 | 01:27 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
While you're at it you might even consider welding a tube in the middle before boxing.
https://www.thirdgen.org/techbb2/sho...hreadid=247409
Old Jun 27, 2005 | 02:17 AM
83 Crossfire TA's Avatar
Welding a tube is just making them unnecessarily heavy, and the larger the crossection of the structure with the same amount of material the stronger it is, so adding the same amount of steel to the outside will result in a stronger arm
Cutting the sides off will also result in a weaker arm then leaving them.
FWIW, I’ve done this 2 different ways, in one case I just cut a sheet metal pattern that was the same thickness as what the arms were made of by tracing the arms and welding it on. The second way I’ve done it is buy just getting a 1.25” x 1/8” strip at the hardware store and just welding that the whole way across. Both work fine, just be careful to only weld about 1” at a time and space your welds well apart to keep from warping things… it won’t be as pretty but it will come out much better.
Here are a couple of pics of the ones done with the cut out sheet metal (eventually the bushings were replaced):
Attached Thumbnails boxing in my lca's-boxedarms_00-10-17_03-small
Old Jun 27, 2005 | 02:18 AM
It's really much smoother then it looks but between the gloss paint, flash, halogen lighting and the stop/starting the welds look a little lumpy (this was right after I bought the welder also)
Attached Thumbnails boxing in my lca's-boxedarms_00-10-17_09-small
Old Jun 27, 2005 | 02:22 AM
Here is a PHR done with the 1/8” thick strip (I can’t find pics of the matching LCAs), just welded, no grinding:
Attached Thumbnails boxing in my lca's-panhardrod_01-02-14_01-small
Old Jun 27, 2005 | 02:23 AM
here's the same piece cleaned up, painted, poly bushings installed and drilled for zirks:
Attached Thumbnails boxing in my lca's-panhardrod_01-02-19_02-small
Old Jun 27, 2005 | 02:31 PM
454transam's Avatar
Engine: 454
cool thanks for the pics and the info thatll really help when i do me and my buddies
Old Jul 2, 2005 | 01:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Crossfire: Why drill for zerk fittings? Is that for a certain type of bushing that takes normal grease, or do you use polybushing grease in a gun?
I just greased the outside of my sway bar bushing with the supplied tube, and put it in, without thought to a fitting, but that sounds like a neat addition....
Old Jul 3, 2005 | 03:04 AM
normal chassis grease is fine for poly bushings.
Old Jul 3, 2005 | 11:15 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
There are also a few other posts on this board where I showed how I did mine. I did them just like the ones above but painted them red.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
