Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Turn your camaro into a Viper........
Old Apr 22, 2006 | 12:52 AM
  #101
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
well i guess its ok to run high compression and maybe 2 psi boost at tops.
Old Apr 22, 2006 | 12:54 AM
  #102
straight's Avatar
Car: 1991 camaro + Dodge
first off . ok , i dont have high enducation on this stuff this is why my mechanic comes in .but i appreciate the time you guys take to help me out not the best way but ive seen worse...i did not know what was causing my prestone to vanish that fast ...ok go to garage talk says either cracked heads or head gasket ok....a few day later after getting mutiple same responces i bring car to him , they take it off and noticed ripped head gasket about 2mm makes a diff in power let me tell you.Anyway sent heads to get ported and spring change......yadi yada they i asked do the pistons look ok ..pretty old looking so asked him whats the best pistons he thinks is best (was thinking for forged diamonds ) but he said dome pistons were used in drag races untill banned so why not get some awsome pistons after we got them i read on a site that when getting turbo changing pistons is a must ...so i asking him again i read in a site yadi yada...again said should be no problem (second time for head gasket) well since my car is already in shop^with it guess it going to stay a few more day cause i got to change pistons now witch sucks cause its more $$ from my ***....
Old Apr 22, 2006 | 12:56 AM
  #103
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
with an o-ringed block, copper gaskets, forged everything, studs, air to water intercooler, good gas (110octane +) and conservative timing, sure, you can run big boost and high compression...but you risk blowin the rings shut, or poundin' the ringlands closed. it's not a very realistic thing on a 19 y/o's budget.
  #104
straight's Avatar
nah i love those rim and clearly paid enough for them to get hurt i got other set...2 am man i got to be going to bed i work in a few hours
hey man if there 1 thing i know best ...Dont question my budget i never got nothing my whole life i had to work hard even at 16 to support my mom because of my ****ing abusive father enjoying nothing but taking my 4 wheeler and selling it for 600 $ for the same year ...bought me a camaro and ill modify it. AND NOTHING WILL STAND IN MY WAY LETS MAKE THAT CLEAR
Old Apr 22, 2006 | 01:02 AM
  #105
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
at least modify it correctly.
  #106
mw66nova's Avatar
Engine: 7.0L
ok, looks like you guys made a few mistakes here. one was not being educated, you should have done WAY more research on the forced induction bit before you just went out and did it. second thing, you listened to an ignorant mechanic. just because he's got 27 years experience, doesn't mean he's got good experience.
domed pistons are not illegal in any way shape or form. the stockers and super stockers and lots of other classes will only allow a certain type of piston in their class, but for all out outlaw type of racing (the kind were you make the rules) you can pretty much run whatever you want.
do you even know what the compression for the motor is? if you want to run 8-12 pounds of boost, and keep it pump gas friendly, i'd say your gonna want to run a piston that will net you roughly 8.5:1 c/r. jegs and summit sells the speed pro power-forged pistons and they have a dished piston that i think nets 8.3:1 with a 64cc head. they are about $280 or so for the set.
FIRST THINGS FIRST though...GET A NEW MECHANIC!!!
the budget thing is strictly coming from experience my friend...nothing more, nothing less. i'm not much older than you sitting down here at 21, but because of my budget, i end up fabbing a ton of stuff up instead of spending my money...it's gotta go in the gas tank yo!
Old Apr 22, 2006 | 01:06 AM
  #107
straight's Avatar
ill right that down , its to late now , car has only the block standing cant change mechanics now...live and learn (the hard way in this case)
yeah i cutting down of modifing after this one...untill gaz goes down..summers coming and got yard work and house work to do before it goes for sale , every modyfication came from savin in winter witch turned out to be more than i expected but its always like that nothing goes as planned
Old Apr 22, 2006 | 01:12 AM
  #108
mw66nova's Avatar
Engine: 7.0L
alright guys, it's time for bed...goodnight
Old Apr 22, 2006 | 01:13 AM
  #109
straight's Avatar
now that im thinking of it , how in gods name did you know im 19?
THANKS FOR EVERYTHING I LEARNED QUITE A FEW THINGS THIS MORNING AND MY MECHANIC WILL TO ....WELL APPRECIATED EVERYONE
Old Apr 22, 2006 | 01:18 AM
  #110
mw66nova's Avatar
Engine: 7.0L
your age is in your "public profile"...i check those before i get into a debate, normally so i know how to handle myself...cause had you been a 35 y/o, i may have thought differently how i acted or reacted...if you were 35 and asking the questions you were, or claiming the things you were, i'd have probably tried to figure out how to get to montreal so i could personally slap you in the face, but since your 19, i figured i'd go easy on ya, cause your obviously new to this deal and your still learning.
  #111
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i know you are born September 4, 1986
Old Apr 22, 2006 | 01:20 AM
  #112
mw66nova's Avatar
Engine: 7.0L
and you were born February 10, 1985...
Old Apr 22, 2006 | 01:21 AM
  #113
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
LMMFBO!!!!
Best hijack 'evar'!!
Kid, go buy a few books before anything else and spend some good quality time with them. If you depend on others entirely you are going to get continually ripped off until you enter the grave.
Old Apr 22, 2006 | 03:11 AM
  #114
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
im 19 as well, but learn and then start to educate other on things. its a clean car, just make it your own.
Old Apr 22, 2006 | 03:39 AM
  #115
Twisted92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L 350 TPI
wow cant believe i just read all that. my head hurts now lol
Old Apr 22, 2006 | 09:36 AM
  #116
mw66nova's Avatar
Engine: 7.0L
i can't believe you stayed up till 3:30 am to read it all!
Old Apr 22, 2006 | 09:56 AM
  #117
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
But it was good entertainment value
Old Apr 22, 2006 | 12:53 PM
  #118
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I want my 5 minutes back
Good god that was a waist of time.
Old Apr 22, 2006 | 01:50 PM
  #119
mw66nova's Avatar
Engine: 7.0L
but you know what? he came out on top cause he realized he's in over his head (if in fact he's actually telling the truth about the turbos) and his mechanic is a dumba$$!
Old Apr 22, 2006 | 02:07 PM
  #120
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Good call!
But, playing the devil's advocate... I'm not so sure straight has any of the things he says he does.
I think the posted Edelbrock pics look like one of Vic's poster children and not a real engine in a real car. The lack of a memory card in a camera sounds like a supporting excuse. Trolling comes to my mind... but that is up to y'all to decide.
Trolling: Deliberately posting false information in order to elicit responses from people who really want to help. A typical response might be, "No, Bart Simpson was NOT one of our founding fathers."- Vikont Solutions Corp.::Technical Glossary
Old Apr 22, 2006 | 04:39 PM
  #121
straight's Avatar
i wont try to get mad here....ive over this to many times .....think of it if i had my car with me right now do you honestly think id be typing right now?
No ill be cruising ...looking at chics and so on...
Old Apr 22, 2006 | 06:34 PM
  #122
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
with pics to post right?
remember we are here to help, not hurt. -well cant speak for everyone, but most of us are.
Old Apr 22, 2006 | 07:04 PM
  #123
FireHwk's Avatar
Car: 92 camaro vert.
Engine: 305 TBI
Axle/Gears: 4th gen with 3:42
Man I wish I knew as much as you guys do! Its hard to understand all of this stuff. I hope the few years that i'm going to spend in school is going to tech me all this stuff.
Old Apr 22, 2006 | 07:24 PM
  #124
Chr1s46536's Avatar
Car: 91 RS
Engine: 305 TBI
Ok what time should i tune in for the 2nd episode. for filling some down time at home. haha
Old Apr 22, 2006 | 08:19 PM
  #125
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
And going and going and going...
Old May 8, 2006 | 02:38 AM
  #126
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
so um... That was different, but what about the Viper? or was it a High compression quad-Turbo monster as well?
Sorry, after reading all that I had to make SOME stupid comment.
Old May 21, 2006 | 10:55 PM
  #127
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Sorry i'm late getting in on this.......I'm so embarrased to say I'm Canadian, right now!
Old May 21, 2006 | 11:27 PM
  #128
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Yeah 10.XX at 116... not even that in the 1/8th... the speed is off...
Hell I will be happy with good lower side 12's with this HSR equipped 383 W/2K stall, 2055's, magnaflow cat back, SFC's and rear LCA's...
Which I think is completely realistic.
Straight, your car looks nice... but keep talking like this and it will end up getting dicked over by someone you have mouth'd off too.
Old May 25, 2006 | 10:19 AM
  #129
killa_b's Avatar
Quite entertaining indeed when someone makes up a bunch of crap even though they obviosly dont know what their talking about and just trying to "sound" cool. the thing i dont get is why some people have to try and make themselves look better to a bunch of people they dont even know?
just my 2 cents
BTY my 92 lo3 is stock and slow but i dont really care what others think of it cause i love my third gen and i may not post but you guys here rock very helpful in times of need to us brokeass's trying to keep our cars running
Old May 25, 2006 | 01:31 PM
  #130
JBert's Avatar
Car: Looking
Wow, what a waste of time.
I'll make this simple. You want people to shut up, show us pics. If not, give me your address, and I'll go take pics for you when I'm up there in a few weeks.
Of course, we could go on and on about how your full of BS!
Old May 26, 2006 | 11:22 AM
  #131
mw66nova's Avatar
Engine: 7.0L
would you guys drop it already?
Old May 27, 2006 | 09:22 PM
  #132
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Old May 27, 2006 | 09:44 PM
  #133
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Nice Av! He's missing the runes around him though, where'd you find the pic?
Old Jun 16, 2006 | 09:27 PM
  #134
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
he might have meant dished, rather than domed. he probley dosent know the diferance.
Old Jun 29, 2006 | 12:11 AM
  #135
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I figured I better post this for "STRAIGHT" and the 20 minutes he took to format each post
Old Jul 1, 2006 | 03:58 PM
  #136
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
LOLOL
Old Jul 6, 2006 | 10:23 PM
  #137
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Old Jul 7, 2006 | 04:49 PM
  #138
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
why hasn't a mod locked this thread already?
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 9, 2015 01:15 PM
